05-25-2008, 03:48 PM | #1 |
Quarry Creeper Join Date: May 2008 Location: looking for sponsors
| battery mounting
I run the axial low cog battery servo/mount on my ax-10 and the battery has come apart like 3 times. so where do you guys mount ur batts or is there a fix for my problem?Help would be nice
05-25-2008, 05:37 PM | #2 |
RCC Addict Join Date: Jan 2008 Location: Wetlands
Dont know what you meen by your battery coming apart. You may want to try a li-po battery. I have the same low CG mount and all i need to keep the battery in place is velcro(hook&loop) |
05-25-2008, 05:51 PM | #3 |
Rock Crawler Join Date: Dec 2007 Location: T1E Country
I am probably one of the few that have saddle packs mounted out back. I have PLENTY of weight up front though. How/why are your packs coming apart? Do you mean coming loose during runs? |
05-25-2008, 06:05 PM | #4 |
RCC Addict Join Date: Dec 2007 Location: On The Lake
I run an 8 cell split pack on my front axles, the packs are mounted on battery plates from The Crawler Store with zip ties |
05-25-2008, 11:59 PM | #5 |
Quarry Creeper Join Date: Nov 2007 Location: Orygun
Ditto.......run them on the front axle. |
05-26-2008, 01:03 AM | #6 |
how much in all the battery pack and the mounts from the craler store cost?
05-26-2008, 01:24 AM | #7 |
Newbie Join Date: Jan 2008 Location: Esparto
some pictures of your setup my help to understand your problem better! I run a 7 cell split pack on my front axle on home made plates no problems. Same as Hotrodvw setup above. |
05-26-2008, 08:32 AM | #8 |
I'm not using any plates. I screwed the velcro straps right to the top of the axle. I think I paid about $35.00 for this battery from CBP.com.
05-26-2008, 10:43 AM | #9 |
Umm i cant really get you guys a pick but ill kinda try.
05-26-2008, 10:54 AM | #10 |
here it is i run a 6 cell saddle pack 3 cells on top of the servo and 3 on the tray here is the tray here is whats happening to my batterys! Last edited by life_livin; 05-26-2008 at 10:58 AM. Reason: tried |
05-26-2008, 10:56 AM | #11 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
Heat shrink tubing, and practice on the soldering. I usually tack my battery's together with CA glue first,then solder the bars on then heat shrink.
05-26-2008, 10:57 AM | #12 |
Solder your pack back together, and use GOOP to glue the cells together in the valleys where they meet.
05-26-2008, 11:04 AM | #13 |
hey thanks guys. I think i am going to order the packs from the crawler store.Hotrod do u run them?? also btw what do you mount you electronics on?nice rid btw
05-26-2008, 12:42 PM | #14 |
05-26-2008, 01:05 PM | #15 |
What do you mean, how do i run them??
05-26-2008, 01:07 PM | #16 |
05-26-2008, 01:27 PM | #17 |
| I was refering to him using the lipo front plate for a split pack instead of using the center servo mount and splitting the packs as in the picture you posted above. I made plates for my 7 cell split packs & you attached your velcro straps to the axle no plates. I assumed he was asking how you mounted (used) your battery packs!
05-26-2008, 02:39 PM | #18 |
hotrod i meant what do you use to mount your rx and esc
05-26-2008, 04:36 PM | #19 |
That would be my stock battery mounting plate, and the U shaped brackets that mouted it to the chassis. I cut it in half, and mouted the rec. and esc to each side. Here's a bit of a better picture. |
05-26-2008, 04:56 PM | #20 |
i will be doing this!!I am going to order the crawlerstores battery 8 cell split and just screw down the straps.
