03-07-2009, 06:38 PM | #41 |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
My current setup with the GC2,moved the lipo tray to the servo mount and useing Losi white springs with 50wt on all four corners. I can't say enough about how well this chassis works. |
03-07-2009, 06:42 PM | #42 |
That looks a lot better than the saddle packs Dave How much did your axle weights end up at?
03-08-2009, 10:16 AM | #43 |
| It does clean things up a bit.I ended up with my smaller pieces of Tungsten ,only 4ozs a piece. I still can't get over the performance difference the Holmes Hobbies 2 cell lipo made over my 7 cell nimh.If anybody's trying to decide weather to go Lipo or not,GO FOR IT !
03-09-2009, 02:08 PM | #44 |
TN State Champ 11,12,13 Join Date: Oct 2008 Location: KTM Talk.com
| GC-2 Is Awesome!
Nice build. I just got my GC-2 and ran it for the first time this weekend at a local gtg and pulled lines my stock Axial never would have. I love this chassis!! I will be using your idea for the mounting of my 3 cell 2000mAh thunder power lipo between the front links. It looks like you used the stock Axial battery plate cut down...thats what I'm going to use. I have been using lexan zip tied between the links but, yours looks like it wouldn't interfer with the suspension cycle. I had to move my rear upper links inboard just a bit to free up the rear suspension. I see that you are running yours wide, do you have any problems with limited rear articulation?
03-09-2009, 04:19 PM | #45 | |
RCC Addict Join Date: Feb 2007 Location: LRC
03-09-2009, 04:26 PM | #46 |
03-09-2009, 04:43 PM | #47 |
Quarry Creeper Join Date: Jun 2007 Location: Waipahu
03-09-2009, 05:26 PM | #48 |
Rock Crawler Join Date: Dec 2008 Location: Over at yo mama's house
how do i get ahold of one of my very own? the setup looks great. cg low and good looking chassis to boot.
03-09-2009, 05:34 PM | #49 |
03-09-2009, 07:23 PM | #50 |
03-10-2009, 06:16 AM | #51 |
| I looked at your set-up again and noticed that I don't have my rear shocks spaced away from the chassis at the top as much as you or Gatekeeper. I will try more spacing and moving the links back. I love all the mounting options on this chassis. |
03-21-2009, 03:10 PM | #52 |
| Spacing the shocks out is the key to the best handling setup with this chassis, in my opinion.
03-23-2009, 07:00 AM | #53 |
I spaced my shocks out and lowered the rear upper links one hole and this helped out a lot. This is an awesome chassis. I got my first top ten finish this weekend with a 7th place and this chassis was key in that. It just seemed to walk up lines that others were bouncing around on and not making. Thanks Austin for an awesome chassis, now I'm waiting for the next run of the 1.9 GC-2. A few pics. |
03-23-2009, 08:46 AM | #54 | |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
03-24-2009, 05:55 PM | #55 | |
03-24-2009, 05:59 PM | #56 |
03-24-2009, 06:09 PM | #57 |
Rock Crawler Join Date: Apr 2008 Location: Highlands Ranch, Co.
03-24-2009, 08:48 PM | #58 | |
I wanna be Dave Join Date: Jan 2008 Location: Arat Alabama
He is special in an Obama bowling score way | |
03-24-2009, 09:08 PM | #59 |
Rock Stacker Join Date: Jul 2008 Location: Tallahassee
03-24-2009, 10:07 PM | #60 |
Quarry Creeper Join Date: Nov 2007 Location: Kansass
| What's the advantage if any to running your upper links on the axle so far apart? I run mine close together, would this be something to consider changing? |
