05-31-2008, 10:50 PM | #1 |
Newbie Join Date: May 2008 Location: sulphur
| quick question
im new to crawling and im wanting to upgrade the suspension links on my ax-10 and im wanting to know if the aluminium links come with rod ends or not and if not were can i get some at. thanks for all the info
05-31-2008, 10:59 PM | #2 |
Rock Crawler Join Date: Apr 2008 Location: Lexington
Not sure where you're talking about buying from or what links you're talking about, but I can pretty surely say no they won't come with the rod ends. A lot of places sell extra rod ends, but also, your ax-10 kit probably has spares. Why can't you just use the ends you currently have on there though if you are swapping links out?
05-31-2008, 11:05 PM | #3 |
Rock Crawler Join Date: Aug 2007 Location: Columbia, TN
Yup, for the most part they don't come with the rod ends unless you get something like these. http://www.shop.rpphobby.com/product...&productId=790 Other than that, several of the vendors sell the factory parts trees with the rod ends. http://www.shop.rpphobby.com/product...&productId=808 |
06-01-2008, 01:36 AM | #4 |
Rock Stacker Join Date: Mar 2008 Location: San Carlos
| If you buy replacement aluminum links they will not come with new rodends.
06-01-2008, 05:24 AM | #5 |
RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
When you buy new links , they do not come with rod ends. But you can purchase them at any LHS in your area or from one of the vendor from the vendors section. Traxxas makes a variety (revo,jato,stampede) rod ends.
06-01-2008, 08:52 AM | #6 |
i should have been more specific on the model i have . i have the rtr rock racer version of the ax10. thats y i m asking about wat type of rod ends i need to get so i can get some of the aluminium suspesion links
06-01-2008, 08:54 AM | #7 | |
will those links work on the front and rear lowers or are those for the front or rear only | |
06-01-2008, 12:53 PM | #8 | |
Newbie Join Date: May 2008 Location: almost StL
Thats a good question. I just measured my stock RTR lower links and they measured right about 5". the Hot Racing links measure just about 4". would that 1" difference matter or not because i was just about to order these. | |
06-01-2008, 12:54 PM | #9 |
Newbie Join Date: Apr 2008 Location: Worcestershire, UK
I use Axial 30° lowers for both the front and rear, and the standard 55mm uppers with extra spacers for a 4-link upper arrangement - it really helps me.
06-01-2008, 06:57 PM | #10 |
wat size links do i need , 6x101, or 6x106
06-02-2008, 12:21 AM | #11 |
Mine are 6 x 101mm 30°
