08-16-2008, 05:19 AM | #61 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
how are those front links working out for you outboarded on the axle?? you get tire rub at full lock? and full lock flex on that side??
08-16-2008, 08:32 AM | #62 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
08-16-2008, 11:48 PM | #63 |
08-17-2008, 09:49 AM | #64 |
Quarry Creeper Join Date: Dec 2007 Location: ON THE "EDGE"
I have both front and rear links outboard on my axles. even with the Axial CVDs, I get a slight rub but I think when i move my links more toward the center of the skidplate (CDW), it should eliminate even that rub. I saw more of a reduction just by moving the rear links outboard at the axle but it did help a little more when I moved the front links outboard as well.
08-18-2008, 08:37 AM | #65 |
RCC Addict Join Date: Jul 2008 Location: Sin City
So what exactly are the generally accepted types of ''rock racing'' are we talking about solid axle crawler type trucks on an offroad track or time attack plus gates from course to course? this sounds like something that would be really fun to build for.
08-18-2008, 08:39 AM | #66 |
| That's about right. We usually have a few jumps, some dirt track, and rock obstacles spread throughout the course.
08-18-2008, 02:55 PM | #67 |
Quarry Creeper Join Date: Jul 2008 Location: Galt
Do you have pics of your chassis without the body on? I'm curious to know how you mounted the battery. I'm guessing that for a rock racer you don't want to have a whole lot of weight on the axles to reduce unsprung weight, unlike a crawler where most of the weight seems to be placed directly on the front axle. |
08-19-2008, 03:38 PM | #68 |
08-19-2008, 03:43 PM | #69 |
Rock Crawler Join Date: Aug 2007 Location: Tucson
i am watching
08-19-2008, 10:41 PM | #70 |
Quarry Creeper Join Date: Mar 2004
Are you still running the stock RTR ESC on your ride? If so, how is it holding up to the power of the lipo? Thanks dIma |
08-19-2008, 10:46 PM | #71 | ||
I just switched to a Super Rooster. The 12t motor and 3 cell lipo burned up the stock ESC. | ||
08-23-2008, 12:07 AM | #72 |
08-23-2008, 07:37 AM | #73 |
08-25-2008, 05:38 PM | #74 |
Bender- Have you had problems with the plastic upper link mounts on the axle wearing out? The upper link mounts on my RTR allow the axle to wrap nearly 5 degrees! |
08-25-2008, 06:18 PM | #75 |
Rock Crawler Join Date: Sep 2007 Location: Denmark
| Awesome Rock racer They use 7T BL motors on some AX-10īs in Finland They use them for Formula Off-road racing http://www.4x4offroads.com/rc-formul...n-finland.html |
08-25-2008, 06:22 PM | #76 | ||
08-25-2008, 06:28 PM | #77 |
08-25-2008, 06:45 PM | #78 |
| Aluminum links won't help my problem though. The plastic links themselves seem to be OK, but where the 3-link ball joins to the mount on the axle, the ball has a lot of slop inside the mount. Does yours have a similar problem?
08-25-2008, 06:51 PM | #79 | |
Rock Stacker Join Date: Apr 2008 Location: Clermont
http://www.youtube.com/watch?v=ApoIwaqe3nI&fmt=18 | |
08-25-2008, 09:15 PM | #80 |
I wanna be Dave Join Date: Aug 2008 Location: Austin, TX, USA
Fantastic! Now I want one! Tommy |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-ax-10-scorpion/122056-rtr-ax10-gone-rock-racer.html | ||||
Axial AX10 Scorpion: RTR/Rock Racer Tips and Tricks Build | This thread | Refback | 10-05-2011 05:55 AM |
