| | #1 |
| Rock Stacker Join Date: Aug 2007 Location: Switzerland
| I am building up a Xtrail. I am looking for some shockes because the stock axial ones are to long and I dont like the droop setup. Now I found these shocks : http://www.losi.com/Products/Feature...rodId=LOSA5082 Those are about 100mm long and I guess they could fit quite good. Does anyone of you have expierence with them. Are the okay? |
| Sponsored Links | |
| | #2 |
| I wanna be Dave Join Date: May 2006 Location: AZ - In The 928
| They are THE BEST crawler shocks. You will hear more good things about these shocks than any other. Super smooth and totaly worth the cost. |
| | #3 |
| RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
| I would'nt say there the best, but a good option. Personaly I'm a big fan of Traxxas Big Bores. |
| | #4 |
| Pebble Pounder Join Date: Apr 2008 Location: Concord
| These are the best shocks ive found for the ax10 yet. They are very smooth and dont leak. The only down side is that the stock mounts are not drilled out enough for 3mm screws (like the stock ax10 screws). Its a rather easy fix for a great set of shocks. Also there is no ball joint at the top of the shock. Even so defenatly recommended. |
| | #5 |
| Newbie Join Date: Jan 2008 Location: B-Town
| I just bought these exact shocks last weekend from LHS. I am going to try and build and install them this weekend. I was wondering what weight of oil are people running in them? Rusty |
| | #6 |
| Thanks for the reply. Unfortunally I screw up my measurements. 100mm ( 4") is to long for the Xtrail Chassis. With a 100mm Shock i would get about 85mm belly clearance. I think this is to much. So I will lock for a shock about 85mm. |
| | #7 | |
| 2006 2.2 National Champ ![]() Join Date: Dec 2004 Location: Driving my R/C rototiller
| | #8 |
| MadDogRC LLC ![]() Join Date: Mar 2007 Location: Petaluma
| I believe you can also buy a shorter version by piecing together the body, piston, seals and shafts. Not sure of the lenght but they are for the front of the XXX. The 100mm are the rear for the XXX. |
| | #9 |
| Good point bender. Didnt tought about it. Still new to crawlers. Do you know how much travel the Losi Shocks have? Thanks for the Input. |
| | #10 |
| RCC Addict Join Date: Feb 2005 Location: Minneapolis
| I personally don't like the Losi shocks. I just can't get them to stop leaking. Two of us locally bought the crawler shocks and neither of us can keep oil in them. Even tried replacing the o-ring cartridges with new ones, still leak. Never had this big of an issue when I ran them on electric cars, so not sure what the deal is. |
| | #11 |
| Quarry Creeper Join Date: Mar 2008 Location: san pancho, ca
| | #12 |
| RCC Addict ![]() Join Date: Feb 2006 Location: ccxc
| | #13 |
| Too much articulation can be a bad thing. |
| | #14 |
| Newbie Join Date: Apr 2008 Location: Orange County, Ca
| They are one the best upgrades i have done. i run 55wt and the traxxas rod ends. i have had no leaking problems and it sits alot lower. money well spent. |
| Thread Tools | |
| Display Modes | |
