Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: Homemade Battery plates/weigh station
Old 06-11-2008, 08:41 PM   #1
Default Homemade Battery plates/weigh station
I fabed these up today out of some 3/4" X 1/8" aluminum stock.
I then proceeded to add 1oz of weights to the underside of each plate.
Here are the batteries mounted (its a pic without the weights but you get the idea)
I'm gonna try to make some 4 link plates tomorrow. What do you think??
chops1sc is offline   Reply With Quote
Old 06-11-2008, 09:03 PM   #2
varcor.org
swell searcher's Avatar
nice job...
swell searcher is offline   Reply With Quote
Old 06-12-2008, 10:10 AM   #3
Lay the batteries down on their sides so they can't short out on the aluminum as they vibrate around on that electrical tape over the ends of your batterys straps...
4RnrRick is offline   Reply With Quote
Old 06-12-2008, 12:00 PM   #4
Looks awesome! I'm probably going to try and fab some up for myself this weekend - we'll see how that pans out though
The Modfather is offline   Reply With Quote
Old 06-12-2008, 12:36 PM   #5
Have you trail-tested it yet?
And most definately be careful of shorting out your packs.
RC Shocker is offline   Reply With Quote
Old 06-12-2008, 01:12 PM   #6
I plan on putting some lexan pieces on the bottom of the pack then re-wrap it with tape. Before I made these the batteries sat right on the axle.
The only "trail" I have even been on is retaining wall blocks in my back yard! But so far they are working very well.
