Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: Hump packs
Old 06-11-2008, 10:06 PM   #1
Location: siloam springs, home of the Mid West Challenge 2010
Default Hump packs
Where do you guys recomend getting some? I tried to make one and it flopped. I have just the standard servo on top of the yoke and not mounted on the side any help would be awesome. Thanks in advance
dustin keeler is offline   Reply With Quote
Old 06-11-2008, 10:08 PM   #2
Here's what I did with 8 cells.
Works pretty well, I get the better part of an hour of solid crawling.
chops1sc is offline   Reply With Quote
Old 06-11-2008, 10:12 PM   #3
I had a hard time getting my soldering (misspelled sorry) to stick to the battery, does it have to be a special kind or something?
Old 06-11-2008, 10:14 PM   #4
TEAM MODERATOR
Reflection's Avatar
Johns got some good deals on some nice packs.
Holmes Hobbies.
Reflection is offline   Reply With Quote
Old 06-11-2008, 10:33 PM   #5
Did you use fresh batteries? If so you have to sand a little spot on each end. Use electric-friendly flux to help the solder stick. How hot is your iron?
Old 06-11-2008, 10:39 PM   #6
The batteries were used. Not sure on iron temp but I will try and sand before hitting it agian. Thanks for the advice I did just buy a hump pack from John thanks for the lead you guys rock
Old 06-11-2008, 10:40 PM   #7
That and you always apply heat to the face of the battery then add the solder. The hotter the iron the better as you want to get the surface hot fast and then cool quickly so the heat doesn't soak into the cell.
Metal Masher is offline   Reply With Quote
Old 06-12-2008, 03:50 AM   #8
It really helps when you have a hot iron, I did not get the solder to stick onto cell with my old 30w iron so I bought a 60w one and now its child's play. You just have to watch out not to overheat the cells or you will destroy them. But actually with a hot iron the whole process is faster so the cells heat up less.
trainer is offline   Reply With Quote
