| | #1 |
| ......../-__-\........ ![]() Join Date: Nov 2007 Location: Memphis
| I shall dub thee, "Black Metal Betty" Thanks to CKRC for getting this out to me in a timely fashion. This was my first complete build ever, and I had a blast. I skimped on the body-off pics, for what reason I'm not sure ax10 kit CC Sidewinder with Castlelink for uber settings control Hitec Aggressor 2-chan Novak 55t Losi Claws with cut foams CKRC Stage 2 suspension kit with bent links CKRC 6-cell split 1500mah packs and plates 1 sexy hacked Black Betty ![]() ![]() Last edited by helhedded; 04-01-2011 at 01:57 PM. |
| Sponsored Links | |
| | #2 |
| I've done the skidplate mod and I'm now waiting on a rear Straight axle kit, 2 more bent links, 2 more soft springs, driveshaft rings and some memory foams. So far I've stripped a couple link ends, broken a driveshaft (replaced with stampede shafts), broken a 3-link connector, popped of a shock, and gained a little more play in my rear locker.:-( My set screws on both of my yolks (tranny side) are stripped. It's really weird because the screws on the axle side aren't. What's a good way to remove those set screws? I included some pics of my backyard spot as well. ![]() ![]() ![]() ![]() ![]() ![]() Last edited by helhedded; 08-11-2008 at 08:44 AM. |
| | #3 |
| Quarry Creeper ![]() Join Date: Nov 2007 Location: Bay Area (RWC)
| Sweet set up man. I like it. Damm you got some big rock in your backyard. |
| | #4 |
| | #5 |
| Pebble Pounder Join Date: Jun 2008 Location: Central Florida
| Looking good!! |
| | #6 |
| Rock Crawler Join Date: May 2008 Location: ************************ Why crawl, when you can just jump up there?!
| | #7 |
| when you say issue, do you mean does it get in a bind easily? in that sense, I would say yes. I will add that the flex shot was with me holdiing it that way, and the shocks were fully pressed. can you describe some binding situations that you think a truck like mine would get into? I'm still messing with different set-ups, but I suppose most folks would say that I have too much articulation. |
| | #8 |
| Rock Crawler Join Date: Jan 2008 Location: Arlington, TN
| LOL hey when ya get done makin your rock garden, i might get ya to bring me some rocks too.......lol |
| | #9 |
| Rock Stacker Join Date: Dec 2006 Location: in front of a computer
| something i would suggest is move the rear springs to the front and the fronts to the rear... keep your rear stiffer then the front is |
| | #10 | |
yeah that makes sense. I got some more soft springs on tonight and I put one stock spring on the left rear. that helped the torque twist slightly, but it also makes the truck lean since that one spring on the rear is different. I bet that problem would be fixed if I had all axial springs instead of 3 (wherever ckrc gets them) and one axial. I also installed the rear axle straight deal- no more floppy c hubs and junk. that along with 2 more bent links and some driveshaft rings. | |
| | #11 |
| Quarry Creeper Join Date: Dec 2007 Location: south bay
| 1) the bed looks really cool dovetailed like that. but i woulda bobbed it a little too. 2) the front fenders (or lack there of) looks terrible 3)you need a black metal sticker on that truck (enthroned, mayhem,emporer, god dethroned, angel corpse, dark funeral, naglfar, immortal, dimmu) 4) just drill out those set screws with a really small bit, using the drill you already have 5) dude, thats more flex than you can really use HAVE FUN |
| | #12 | |
| | #13 |
| Pebble Pounder Join Date: May 2008 Location: The Beautiful South
| thanks for all the cool pics. What kind of steering servo are you using, and also battery packs, and their life? |
| | #14 | ||
that's it. I'm changing her name to Death Metal Betty. I chose "Black" because the paint was black, and I used "metal" because that body just screams it when it's hacked and painted black. A Gorgoroth sticker would be pretty sweet, though Quote:
I'm using the Hitec 645mg, and a 6-cell 1500mah pack from CKRC. I get about an hour of run time. | ||
| | #15 |
| Rock Stacker Join Date: May 2008 Location: The great U.P. (Northern Michigan)
| i love wat you did w/ the body, and almost no green |
| | #16 |
| thanks!! New stuff : Rear straight axles 2 more ckrc bent links Traxxas shafts shaft rings from TCS custom hybrid losi/proline mem foams ... limited my articulation to about 45 degrees...it was near 90. It drives a lot better with less flex. Torque twist is getting better. I preloaded the LR stock axial blue with one of my ssmt shock springs. :-P I've also learned that driving my rig with the shocks upside down with a lot of flex (about 60 degrees at the time) was a bad idea. I went down to the river over the weekend and popped off a couple spewing oil everywhere! The doors and rear where trimmed up some more. From ![]() to ![]() ![]() ![]() |
| | #17 |
| lookin good |
| | #18 |
| Quarry Creeper Join Date: Jan 2006 Location: Atlanta GA
| nice man. |
| | #19 |
| Beef Tube Supplier ![]() Join Date: Jul 2008 Location: Southwestern, Ohio
| Looking Good! |
| | #20 |
| Thread Tools | |
| Display Modes | |
