Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: Axial Universal Joints
Old 06-16-2008, 05:27 PM   #1
Axial's Avatar
Default Axial Universal Joints
AX10 Scorpion Universal Joints
  • Turning angle up to 42 degrees
  • Heavy duty hardened steel construction
  • No setscrews needed, cross pin held in place by aluminum ring
  • Sold in set of two, why buy four when you only need two
Part Info
AX30460 AX10 Scorpion Universal Joint Axle (2pcs)
AX30461 AX10 Scorpion Universal Joint Axle Shaft (2pcs)
AX30462 AX10 Scorpion Universal Joint Rebuild kit (2pcs)
AX30464 AX10 Scorpion Universal Set (2pcs)
http://www.axialracing.com/ftp/ax10o...niv_joint.html
Axial is offline   Reply With Quote
Old 06-16-2008, 05:30 PM   #2
When will these be available?
HiloDB1 is offline   Reply With Quote
Old 06-16-2008, 05:32 PM   #3
Axial's Avatar
We started shipping them last week, most of the vendors here should have them already or within a short amount of time.
Thanks,
Axial
Old 06-16-2008, 05:37 PM   #4
Thanks, Ive been waiting for these ever since I seen them on the site several weeks back. Will be ordering a set soon
Old 06-16-2008, 10:00 PM   #5
Those are sweet. Are you guys working on some HD drive shafts by any chance?
Jman08 is offline   Reply With Quote
Old 06-16-2008, 11:20 PM   #6
Can we get those in chromoly??
robert97dodge is offline   Reply With Quote
Old 06-16-2008, 11:25 PM   #7
Moderator
whoodie's Avatar
Yeah I want to know what material these are specifically. Actually just give me a hardness and I can take it from there.
whoodie is offline   Reply With Quote
Old 06-17-2008, 01:36 AM   #8
Gavyn is my BFFL
Nabil's Avatar
the housings have been availiable for a long time
Nabil is online now   Reply With Quote
Old 06-17-2008, 02:01 AM   #9
So they have... ... deleted my stupid question.
2JSC is offline   Reply With Quote
Old 07-02-2008, 02:31 PM   #10
2006 2.2 National Champ
BENDER's Avatar
I'm not sure what material was used, but the shafts have proven themselves to be plenty durable so far.
Nice too see these available now Matt, I love mine. The extra steering gained over the stock set-up, and zero backlash are key for comp situations.
BENDER is offline   Reply With Quote
Old 07-02-2008, 08:47 PM   #11
Keep it real
Tanis's Avatar
Exactly, mine should be here tomorrow Nice work Mr. Kearney
Tanis is offline   Reply With Quote
Old 07-02-2008, 09:02 PM   #12
I have got these on order along with the RCP knuckles to replace my stock shafts/RC4WD knuckles.
Can't wait to see how much better the steering will be.
Hildy is offline   Reply With Quote
Old 07-02-2008, 09:52 PM   #13
Now you need to make a version with integral wheel wideners!
sedanman67 is offline   Reply With Quote
Old 07-03-2008, 07:26 AM   #14
binaryterror's Avatar
Not really, just buy full offset wheels.
binaryterror is offline   Reply With Quote
Old 07-03-2008, 07:49 AM   #15
Moderator
whoodie's Avatar
X2
Old 07-03-2008, 09:18 AM   #16
Nice job Axial - got mine installed & tested - they work great - much improvement over stock. I tried the MIP cvd's & did not like the fact that you had to be very careful how tight the wheel lock nut could be - these are much better.
Yawzer is offline   Reply With Quote
Old 07-03-2008, 10:08 AM   #17
SCALE PERFORMANCE PARTS
Locked Up's Avatar
Do the MIPs strip or something?
Locked Up is offline   Reply With Quote
Old 07-03-2008, 10:17 AM   #18
Moderator
whoodie's Avatar
I spoke with Brandon at MIP 2 days ago and he told me that the stub shafts have been redesigned to include a lip that the outer bearing inner race will seat on. That way when you crank down on the wheel nuts it should not bind the bearings. He said that they are scheduled for production in 2 weeks time. I suggest that IF you are having problems, call them up and get replacements. He said that the problem exists on certain aftermarket knuckles.
Old 07-03-2008, 11:46 AM   #19
Locked Up - No, they do not strip - the stub shaft was designed just a fuzz short of the axials - so the distance between the inner bearing and the hex pin was a little off - sounds like they are correcting it - hope so - they usually make a great product.
