Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: upper 3 link
Old 06-17-2008, 08:57 PM   #1
Default upper 3 link
the upper 3 link on my ax10 rtr is plastic. And i know i seen some where a 1 piece all aluminum link but i cant find it again. Can some one point me in the right direction
hummer6504x4 is offline   Reply With Quote
Old 06-17-2008, 09:16 PM   #2
<P><A href="http://www3.towerhobbies.com/cgi-bin/wti0001p?&amp;I=LXVAK8&amp;P=7">http://www3.towerhobbies.com/cgi-bin/wti0001p?&amp;I=LXVAK8&amp;P=7</A>&nbsp;this is a sweet lookin upper link</P>
tjarr001 is offline   Reply With Quote
Old 06-18-2008, 01:12 AM   #3
RCP CRAWLERS has them also in different colors,plus there a great vendor
http://www.rcpcrawlers.com/home.php?...ction=0&page=4
TIMZKRAWLER is offline   Reply With Quote
Old 06-18-2008, 04:50 AM   #4
Location: ************************ Why crawl, when you can just jump up there?!
ckrc has some decent alum ones, but why go 3-link when you can go 4? Its the better way to go. Less tourqe steer aswell.
ADDICT is offline   Reply With Quote
Old 06-18-2008, 05:06 AM   #5
JEracing's Avatar
definetely ckrc
JEracing is offline   Reply With Quote
Old 06-18-2008, 09:40 AM   #6
IVE BEEN SZCZERBOTAGED!!
ROLANDROCKSHOP's Avatar
like this? at tower hobbies
ROLANDROCKSHOP is offline   Reply With Quote
Old 06-18-2008, 09:49 AM   #7
Is your upper link flexing. If not i would keep it. I would go 4 link if you were going to spend money for the upper links
tbizzle is offline   Reply With Quote
Old 06-18-2008, 10:04 AM   #8
You can go 4-link and still use the original 55mm upper links too
Fat-Alfie is offline   Reply With Quote
Old 06-18-2008, 06:45 PM   #9
the only reason i wanna keep the 3 link is because i just bought the aluminum 3 link axle mount.
Old 06-18-2008, 06:58 PM   #10
You mean the lower 3 link mount that goes on you axle housing? If thats what your talking about you can still have to use that lower 3 link mount for most 4 link plates.
Old 06-18-2008, 10:23 PM   #11
oh, well i might go for the 4 link then. What are some peices that i will haft to have. you gotta remember, i have a rtr version and i will haft to have rod ends and everything.
