Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: Scored an AX10... now what?
Old 06-18-2008, 12:46 PM   #1
Default Scored an AX10... now what?
I picked up a stock but fully put together AX10 today for $185! It was a demo at my local hobby shop.
My only RC experience is with the 1:6 Nylint crawlers (yes I know).
Lots of plastic on this thing...
Main question is how the hell do you put the front locker in??
What are the major weak points?
Next upgrades?
Yes, I'm searching. There is a ton of info to go through. So any help is greatly appreciated.
flexcj5 is offline   Reply With Quote
Old 06-18-2008, 12:56 PM   #2
go to jasons sticky on the live axial ax10 build thread that should explain it
hustlercrawler is offline   Reply With Quote
Old 06-18-2008, 01:25 PM   #3
Ahh... Thanks. Got the locker installed.
After more research it appears that I purchased the RTR.
Old 06-18-2008, 02:30 PM   #4
My first upgrades would be a front split battery pack, bent links, and tires so far that is what i have done to mine and i got the bug body
ZJ Jarod is offline   Reply With Quote
Old 06-18-2008, 03:08 PM   #5
Well that sucks... got it all together, locker installed and charged the battery, took it into my front yard (flat grass) and broke the plastic yoke on the rear drive shaft!
Old 06-18-2008, 04:30 PM   #6
broke it or did it pop out? it pops out occasionally. if you dont want it to happen agian. get some STEEL stampede yokes and stampede drive lines. have your hobby shop show you how to put them on. its hard but well worth it. for tires get losi claws and get the tcs boomerang plate and do a 4 link
Kranberry is offline   Reply With Quote
Old 06-18-2008, 04:46 PM   #7
yep broke it. the plastic yoke split at the ends.
Old 06-18-2008, 04:54 PM   #8
If its the rtr get rid of the 27 turn & get A Novak Goat system.
dshelowjr is offline   Reply With Quote
