Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: widen there stance?
Old 06-18-2008, 07:35 PM   #1
Default widen there stance?
anybody widen there stance on there scorpion?
topdog909 is offline   Reply With Quote
Old 06-18-2008, 07:50 PM   #2
yep
Dickie691986 is offline   Reply With Quote
Old 06-18-2008, 08:00 PM   #3
Nope
Crab Walker is offline   Reply With Quote
Old 06-18-2008, 08:04 PM   #4
calcat430d's Avatar
maybe
calcat430d is offline   Reply With Quote
Old 06-18-2008, 08:07 PM   #5
Originally Posted by Dickie691986 View Post
yep
Originally Posted by Crab Walker View Post
Nope
Originally Posted by calcat430d View Post
maybe
Quite simply the best 1-2-3 response I have seen on any forum.
Well done gentlemen.
fake edit: re: Wheel Stance - what they said.
The Modfather is offline   Reply With Quote
Old 06-18-2008, 08:10 PM   #6
I used a wheely king widening kit. You'll have to do a bit of dremel work to make the holes big enough to slide over the axle stubs.
I found that my rig was then too wide to fit alot of obstacles without added difficulty, but I needed the extra width in the front or my tires would rub my shocks when turned all the way so I took the wideners out of the rear...and shaved the front wideners down by 1/4 inch on each side. Now I have the clearance I need without being too wide.
Hope that helps
cuzican is offline   Reply With Quote
