Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: X-Treme BTA with Stock Parts
Old 06-19-2008, 05:36 AM   #1
Default X-Treme BTA with Stock Parts
Yes, I am going to do BTA steering with extra steering from stock parts. hopefully i will not need anything other than what comes in every Kit.
First, i have some pics of the stock setup which i am plain not happy with.
Next is a pic of the first problem with BTA and stock components. The suspension mounts are definately in the way.
Next, just nix the mounts and you should be golden. But wait, i want to get rid of that gap between the knuckle arm and the C mount. I am actually only going to use 1 screw for the mount to make clearances.
To get more throw out of the stock crap, i need to find the source of the bindage. it ends up, the extra material on the cups is not even needed at all...it probably keeps wear on the ball down but who gives a shit? i am going to get rid of that.
This sequence of pics shows how to remove the stub shaft without actually taking the knuckle off the C. its so simple!
I marked what i am going to cut off to get some more throw from my axial steering.
updates as i have them.
danielk is online now   Reply With Quote
Old 06-19-2008, 05:43 AM   #2
littleskull99's Avatar
Be carefull how much you take off, I ruined a set of TLT axle stubs taking too much off.
Matt
littleskull99 is offline   Reply With Quote
Old 06-19-2008, 06:04 AM   #3
it ends up, grinding down the edges makes it the best you can utlize anyways. one day i might return to the idea of cutting them down but im just gonna leave it be for now.
Old 06-19-2008, 08:42 AM   #4
Originally Posted by danielk View Post
Why not just counter sink that hole. If you with run it with only one screw it will flex like hell.
Tupers is offline   Reply With Quote
Old 06-19-2008, 08:53 AM   #5
varcor.org
swell searcher's Avatar
Instead of running one bolt to hold the c's on, counter sink the hole with a 3/16 drill bit and find a counter sink bolt to fit, 3mmx8mm. I couldn't find any locally so I just used a short button head screw and jammed it in there after counter sinking the hole.
swell searcher is online now   Reply With Quote
Old 06-19-2008, 09:48 AM   #6
so are you going to mount both the shock and link to that one little plastic mount?
I did and it work for about 15 mins and it fell about a foot. to its death
Way I first installed it and FAILED
Current setup used 1"x1" angle alum. and cut and bent out one end for the link attachment
What is with the I-bolts?
Jeepernick is offline   Reply With Quote
Old 06-19-2008, 10:01 AM   #7
what do you need shock and link mounts for when you run torsion? that answers the question about the EYE-bolts.
i also figured out how to cut the plastic so i could fit the stock screw cut down and have it clear.
Old 06-20-2008, 12:22 AM   #8
Team Y-Town
4xFord's Avatar
Nice work Daniel, I look forward to seeing this thing on the 29th.
4xFord is offline   Reply With Quote
Old 06-20-2008, 02:06 AM   #9
Location: ************************ Why crawl, when you can just jump up there?!
wow... nice job. Im gonna have to do something like this. Good write up aswell
ADDICT is offline   Reply With Quote
