Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: Chip's 08' and a 1/2 comp rig.
Old 06-19-2008, 03:13 PM   #1
ΜΟΛΩΝ ΛΑΒΕ
chip cross's Avatar
Exclamation Chip's 08' and a 1/2 comp rig.
I retired my 08 rig and built my first Axail based rig
Axail axle based GC-2 Chassis
MIP CVD's
H.D. Lockers
H.D. Ring and Pinoins
RCP Aluminum Knuckles and Axle C
RCP Rear lockout with Stainless steel axle shafts
Axail tranny with a VF dig and slipper clutch
Hot Racing Aluminum tranny gears
JR 8711 steering servo
JR 650 dig servo
Mamba max ESC
55 turn lathe motor
CCBEC
MIP Drive shaft in the front
Traxxas slider in the rear
Losi Crawler shocks
Panther Cougar tires
NWTT foams
DX3R
HPI Bug body
Eritex beadlocks with 14 oz total weight in each front wheel
Maxamps 2000 mah 3S lipo
12.5 wb and 9.75 wide
chip cross is offline   Reply With Quote
Old 06-19-2008, 03:25 PM   #2
Yup she's a comper! Sweet build, are you using a aluminum tranny case
JUSTGOINGSLOW is offline   Reply With Quote
Old 06-19-2008, 03:42 PM   #3
ΜΟΛΩΝ ΛΑΒΕ
chip cross's Avatar
Yes it will work with a little Dremel work.
Old 06-19-2008, 04:13 PM   #4
jeepcj578's Avatar
ah 4 tires and a contoler and everyone thinks its a big deal
j/k looks good how do u like the 8711 hehe.
are u using the links i gave u ?
jeepcj578 is offline   Reply With Quote
Old 06-19-2008, 04:37 PM   #5
ΜΟΛΩΝ ΛΑΒΕ
chip cross's Avatar
I love it better keep your fingers clear of the steering links.
Old 06-19-2008, 05:13 PM   #6
Gold Star Baby!
Stormin2u's Avatar
Location: Taylors Falls just hanging with the MNRCRC crew.
Super sweet rig Chip it's got a great parts list, good luck to you with it.
Stormin2u is offline   Reply With Quote
Old 06-19-2008, 06:15 PM   #7
~The Scale Shop~
STANG KILLA SS's Avatar
nice chip!
Old 06-19-2008, 06:18 PM   #8
Axial Team Driver
Brandon's Avatar
LOSER!! Its all about the tlt's
Looks good i guess...
Brandon is offline   Reply With Quote
Old 06-19-2008, 06:44 PM   #9
ΜΟΛΩΝ ΛΑΒΕ
chip cross's Avatar
Originally Posted by STANG KILLA SS View Post
nice chip!
Thanks Bro.
I agree 100 % but I wanted to try the Axail AX-10 axles out.
Old 06-19-2008, 07:50 PM   #10
it'll never work!
danielk is offline   Reply With Quote
Old 06-19-2008, 11:25 PM   #11
Originally Posted by danielk View Post
it'll never work!
Thats only cause of the driver. I call dibs
mississippirocs is online now   Reply With Quote
Old 06-19-2008, 11:44 PM   #12
Good lookin truck Chip
Gatekeeper is offline   Reply With Quote
Old 06-19-2008, 11:47 PM   #13
Keep it real
Tanis's Avatar
I like it............now you just need some tires:-P:-P
Tanis is offline   Reply With Quote
Old 06-20-2008, 12:05 AM   #14
TEAM MODERATOR
Reflection's Avatar
I was thinking.......a body and a motor.
Reflection is offline   Reply With Quote
Old 06-20-2008, 11:12 AM   #15
Nice rig man, looks like a killer setup.
RotaryRush is offline   Reply With Quote
Old 06-20-2008, 02:03 PM   #16
Sick rig dude.
I got to beat the crap out of mine with Axial axles the past few days and it is performing awesome. Bring it on Berg
Hildy is offline   Reply With Quote
Old 06-20-2008, 02:35 PM   #17
Location: ************************ Why crawl, when you can just jump up there?!
that a 2100/11.1v or a 2000mah? i like the rig. Looks like you put a lot of time into it. you added 14oz to each wheel up front? How much did you add to the rear? looking good btw
ADDICT is offline   Reply With Quote
Old 06-20-2008, 03:39 PM   #18
Ultimate RC Decals
BOWTIE's Avatar
looks great!!!
BOWTIE is offline   Reply With Quote
Old 06-20-2008, 06:24 PM   #19
I joined the Band!
you might not ever go back to TLT axles now..
nuts5000 is offline   Reply With Quote
Old 06-20-2008, 10:05 PM   #20
ΜΟΛΩΝ ΛΑΒΕ
chip cross's Avatar
Thanks Austin you did a kickass job on the chassis.
I have some NIP Losi claws if the panthers don't work.
Whats wrong with a bug Steve ? I got a Cobalt 7 T from the Devil (666) if the 55 Turn doesn't work
Thanks are you coming to Shreveport with Bryd ?
Yes it's a 2000 mah 3s pack for a Mini-T tire,wheel,lead weight, and foam = 14 oz per front I only added 4.5 oz of lead weight to each wheel
LINKY http://www.maxamps.com/proddetail.ph...1-Pack&cat=156
Originally Posted by BOWTIE View Post
looks great!!!
Thanks Dude
I already like the fact I can change out a broke axle shaft in about 1 min.
