| | #1 |
| Quarry Creeper Join Date: Apr 2008 Location: Lutterworth, UK
| Ok i have searched but cant find anythng on it but are there any other servo's other than the hitec that fit in the servo mount for the dig im struggling to find one over the pond in england and just wondering if you guys have tryed any others? |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Feb 2008 Location: Hiatus..sutiaH
| As for another servo that fits the mount - I don't know. Use the stock steering servo mount (if you are not using it) and simply drill a couple of holes in it so that it will mount on top of the VF Dig. Simply add the servo mounting points and you can run a full size on it. I am about to go this route as well. Or, if you are not using the stock battery plate cut that up and do the same. This way you won't have to worry about finding a mini servo and you will have more strength to boot. |
| | #3 |
| Losi Factory Pilot ![]() Join Date: Feb 2007 Location: Chucking rocks at your little truck!
| Same size and three times the servo. http://www.horizonhobby.com/Products...dID=JRPS3421SA |
| | #4 |
| Rock Crawler Join Date: Aug 2007 Location: Columbia, TN
| I just put a 645 on mine. Like Doc said, take your stock steering servo mount for the rear if you're not using it, mount the servo mounts on it as they should be, and sit the VF mounting bracket between those two mounts, and drill your holes. Then you can put the standard size servos on there. Worked out much better for me because I just got too frustrated with trying to get the mini servo's to last more than a minute so I could get the dig set up. |
| | #5 |
| Rock Crawler Join Date: Jan 2008 Location: Arlington, TN
| same here, fabbed a mount and had a 3305 laying around |
| Thread Tools | |
| Display Modes | |
