| | #1 |
| RCC Addict ![]() Join Date: Feb 2006 Location: ccxc
| Installed the new MIP driveshafts and flung out a 3/32 x 5/8 cross pin. Crawler is down until I can find another. Anyone know where to get these? |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
| Your LHS might have one, It's a pretty common pin. |
| | #3 |
| RCC Addict Join Date: Oct 2005 Location: $t. Helen$, OR
| or maybe the local Ace Hardware did you really need to post? |
| | #4 |
| yea lol. I can't find it online anywhere. It didn't seem to be common |
| | #5 |
| Moderator ![]() Join Date: Jul 2007 Location: Texas baby!
| | #6 |
| thats the thing...I can't find the sizes but I bet the ones in the cvd kit are smaller........just so mad that this little part has my truck down. |
| | #7 | |
Edit: the CVD kit does not have the crosspins. Your instruction sheet should have the correct part number. | |
| | #8 |
| Perpetual Newbie ![]() Join Date: Oct 2007 Location: Kennewick, Washington
| Order a gauge pin in that diameter from McMaster-Carr and cut it to length with your dremel.Gauge pins are what we machinist measure holes with and are hardend and ground.They are very affordable and you can get them over night if you need. One pin is around 2 inches long so you can cut off extras,and they will not bend or break. Just another option for you to try. Last edited by Cave Dave; 06-19-2008 at 07:45 PM. |
| | #9 |
| Rules? What Rules! ![]() Join Date: Apr 2008 Location: Tallahassee, Fl.
| You may go to your LHS & procure a length of wing wire or piano wire that is the right size (take the part that the pin goes through) & that would work until you can get a rebuild kit. |
| | #10 |
| Quarry Creeper Join Date: Nov 2007 Location: NH
| why not go to the hardware store and buy a 3/32" drill bit and cut 5/8 off the non drilling end? you might even be able to 2 out of one bit. |
| | #11 |
| thats the other wierd one...no part number. just a description. I think I might have t go the 3/32 rod and cut it assuming the LHS has any |
| | #12 |
| | #13 |
| Thanks for the advice. I don't want to be down all weekend |
| | #14 |
| Pebble Pounder Join Date: Dec 2007 Location: Torrance
| If you're really in a jam, just cut down a finishing nail. It would work for a while. |
| | #15 |
| Linux Mint 10 ![]() Join Date: Mar 2008 Location: SSF
| Cut the shank of a drill. |
| | #16 |
| Quarry Creeper Join Date: Jan 2008 Location: fair oaks nor-cal
| yea like jd said i used that same idea with my pede when i used to bash |
| | #17 |
| Rock Stacker Join Date: May 2008 Location: oregon city
| well when you do find one put some shrink wrap (like for electronics) over it so it doesnt come out |
| | #18 |
| Pebble Pounder Join Date: Apr 2008 Location: 22 Acacia Avenue
| use an old hex wrench (you know the little cheesy l shaped ones) that you don't need, cut it down, and now you have a flat spot to crank down the set screw on...Work good... |
| | #19 |
| I put ReD LockTite on the set screw Its not coming off |
| | #20 |
| I did blue loctite and 3/32 bar stock. Works for now. Ordered 25 from Mcmaster Carr, hardened steel mil spec |
| Thread Tools | |
| Display Modes | |
