Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: edge set up
Old 06-19-2008, 06:54 PM   #1
Default edge set up
belly draggers do not do good at my comps i have the edge with losi 4 inch. i have heard of partal droop/sprung set up i search and came up with nothing. any ideas?
revoracer99 is offline   Reply With Quote
Old 06-19-2008, 10:21 PM   #2
I've got a buddy on here running the Losi shocks on his Edge, and I think that's about the most belly clearance you're gonna get out of it. As far as the semi-droop setup that is what I'm running, it's just internal springs both under as well as on top of the piston inside the shock body, but I don't know for sure how well that would work with the Losi's.
MCSCOTT is offline   Reply With Quote
Old 06-23-2008, 06:20 PM   #3
here is my droop sprung setup
Old 06-23-2008, 07:01 PM   #4
Here's mine as it sits now, took out the VF Dig though in favor of the much nicer R2D
HomerJ is offline   Reply With Quote
Old 06-27-2008, 12:49 AM   #5
any suggestions on a good starting point for a tcs edge chassis using stock a10 shocks using internal med springs ? oil weight ? spring rate? and spacer placement ? thanks for any info.
ROCKCAD is offline   Reply With Quote
Old 06-27-2008, 02:52 AM   #6
I do like that edge chassis; looks much more crawler like IMO; even though I really like my baja bug body too.
Boos Boy is offline   Reply With Quote
Old 06-27-2008, 02:59 AM   #7
you are gonna get about 100 different opinions on this. i run the stock shocks with the HPI soft spring inside all 4 under the piston, spacers under the piston, 3/4" (hardware store)firm springs on top of the piston, 100 wt oil in the driver's side rear shock, 60 wt in the pass. rear, no oil in the fronts, 2 part epoxy all the caps to the shock body 'cause i am sick of the caps popping off and this was a last attempt at running the stock shocks.....they suck! it took me about a month to come up with the set up that works for me. kinda all depends on your terrain, driving style, patience level.
nick
8onick is offline   Reply With Quote
Old 06-27-2008, 04:05 PM   #8
all droop here
http://video.google.com/videoplay?do...Pw4d25CQ&hl=en
http://video.google.com/videoplay?do...&q=bprca&hl=en
my old rig you can tell the paint scheem i like!
btw im running med springs half and half traxxas red front and stock rears.im a novice driver so i dont know how much you can lear from my set ups but they do work!
