Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: MIP Driveshaft Quirk
Old 06-19-2008, 10:34 PM   #1
2D
Harvo's Avatar
Default MIP Driveshaft Quirk
I put the new HD MIP driveshaft in the front only of the AX 10.
I haven't figured out what part of the driveshaft causes this to happen, but when I hit half to full throttle, I get a wierd hesitation that starts slowly. At its worst, the front wheels studder stop continuously until I let off the throttle. The tranny never stops turning but the front wheels are (stop/start/stop/start) very quickly. I have noticed this on a steep climb with wheels spinning, and with the weight off completely like holding the truck or when it is high centered.
Today, after closely watching it while holding in my hand I'm stiff baffled. But I put the stock shaft back on and it went away completely.
The only thing I can figure is that the slop you get in an axial axle, along with the heavier rotational weight of the shaft and the heavy spinning wheels cause some type of phase to occur. And the lighter stock shaft doesn't have enough mass to make it happen.
I suppose the solution is to figure out a way to get the slop out of the axle, or leave the MIP out. On a climb, it can really screw you up.
Anyone else notice this?
Harvo is online now   Reply With Quote
Old 06-19-2008, 10:40 PM   #2
no.......but i did throw a damn cross pin out in the weeds somewhere..........now its 2wd
Deezul is offline   Reply With Quote
Old 06-19-2008, 10:45 PM   #3
I don't have the MIP shafts yet, but when I was running 2wd buggies, I would put a small piece of heat shrink on the CDV right over the pins. Works like a champ
The Modfather is offline   Reply With Quote
Old 06-19-2008, 10:59 PM   #4
I am still waiting on my shafts. I ordered them last saturday but they didnt ship until wednesday so hopefully I will get them by the weekend.
robert97dodge is offline   Reply With Quote
Old 06-19-2008, 11:05 PM   #5
Moderator
whoodie's Avatar
The front suspension is in full down travel I am betting and the MIP driveshafts are at their maximum angle. Even though they are a CV, they still have a maximum angle that they can reach. Are you running the suspension completely stock? How about the grub screw? Is it tightened down on the flat all the way?
whoodie is offline   Reply With Quote
Old 06-19-2008, 11:56 PM   #6
NBRCC
hellbentrodder's Avatar
Sounds like the grub screw spinning on the output to me.
hellbentrodder is offline   Reply With Quote
Old 06-20-2008, 12:33 AM   #7
2D
Harvo's Avatar
I checked that. It's tight and not spinning. My suspension is lower than stock. If it is at it's limit, then they would be pretty rough to run on a stock setup. I'm guessing that is it though.
Old 06-20-2008, 12:38 AM   #8
Moderator
whoodie's Avatar
Do the axles droop further down with the truck in the air than stock? Maybe just take some pictures for us to see.
Old 06-20-2008, 12:47 AM   #9
Like someone said earlier. Its most likely at a steep angle and the speed variations are causing that. When the joint is steep it doesnt rotate at a uniform speed, it speeds up and slows down, and at half throttle it must just hit the frequency that makes the front end stutter like that. I had a scaler that did that, and lessening the front driveline angle fixed it completely.
Dumptruck is offline   Reply With Quote
Old 06-20-2008, 01:39 AM   #10
Jus
My Mips are working wonderfully.. No such behavior has occured.. Did you grease the joints real well?
Jus is offline   Reply With Quote
Old 06-20-2008, 01:55 AM   #11
Location: ************************ Why crawl, when you can just jump up there?!
All my mip shafts, on all my rigs are working pefect. Double check your suspension, make sure the shafts are greased and make sure you lock tight the set screws. im loven em
ADDICT is offline   Reply With Quote
Old 06-20-2008, 08:14 AM   #12
i got mine WED and i love them they are SO stout!!! friggin work horse:-P
jmdave69 is offline   Reply With Quote
Old 06-20-2008, 10:39 AM   #13
I've been running my MIP shafts for a couple of days now and all i can say is i love them.
haven't had any problems at all !
MudBoy is offline   Reply With Quote
Old 06-20-2008, 10:43 AM   #14
Who did you order them from?
I ordered mine from RPP and they got here in like three days after i ordered them!
Old 06-20-2008, 11:39 AM   #15
2D
Harvo's Avatar
Thats what I'm thinking. They are greased, set screw is tight, all the ususal stuff checked. I do like it... and I have already beat the crap out of it with no manufacturing or strength issues.
I just can't run it until I work out the quirk.
Old 06-20-2008, 11:47 AM   #16
RPP. I usually order from TCS because they are super fast with everything so far and they were out of stock.
Old 06-20-2008, 12:18 PM   #17
Mine work great. is there a chance you put to much loctite on the set screw and it bled over to the joint? that would cause it to bind.
HURLEYGO3 is offline   Reply With Quote
Old 06-20-2008, 07:11 PM   #18
good point i use to much every time and i had to work it out with the grease supplied and i dont have issues??? hrmmm possibly a weak component in the tranny / engine department??
Old 06-20-2008, 07:23 PM   #19
sniper's Avatar
i had the same problem with the stock drive shafts. only when i pick up the truck and susp. went full droop the shafts were at just enough angle not too bind but put a little force on the joint and cause it to stutter a little. so i dont think its the MIP's just a little too much driveline angle.
I ordered mine from RCP this week cant wait to get them installed.
sniper is offline   Reply With Quote
