| | #1 |
| Beef Tube Supplier ![]() Join Date: Jul 2008 Location: Southwestern, Ohio
| What is the part # for the Stampede HD Shafts and Metal Yokes used to upgrade the stock driveshafts? Thanks in advance! |
| Sponsored Links | |
| | #2 |
| Damn-I need a chump RT!!! ![]() Join Date: Sep 2007 Location: Lost as hell.....
| yokes http://www.rcslot.com/mm5/merchant.m...w=&range_high= and shafts http://www.rcslot.com/mm5/merchant.m...w=&range_high= Good deals to Last edited by yotachump; 07-13-2008 at 10:55 AM. |
| | #3 |
| Thanks yota! |
| | #4 |
| If you have a newer AX10 kit, I see no need to upgrade the yokes, Axial has extended there yoke pins, to the same length as the Traxxas pins. |
| | #5 |
| Moderator ![]() Join Date: Jul 2007 Location: Texas baby!
| If you really don't want to worry about breaking driveshafts I suggest either Revo or T-Maxx driveshafts. I'm running the Revo's and I swear by them. Here is how it can be easily done. Maxx Shafts made easy. It works on Revo shafts as well. You don't need a lathe, you can cut the ears off the yolk with a Dremel. And I stepped down the drill size to a 7/16" |
| Thread Tools | |
| Display Modes | |
