Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: My shocks leak
Old 07-14-2008, 08:27 PM   #1
Default My shocks leak
I'm running internal springs and have tried several differant oil wts. Right now I'm actually using Lucus automotive oil and love the results. Problem is that during all of my experimenting I've yet to get away from my shocks leaking down.
How do ya fix this?
Dollarhide is offline   Reply With Quote
Old 07-14-2008, 08:41 PM   #2
try silicon on the threads, maybe Peramatex Ultra Black and let it sit for a little bit. worked on my buddies.
wyocrawler is offline   Reply With Quote
Old 07-14-2008, 08:44 PM   #3
thanks, that sounda like a good idea. So, I'm guessing this is a common problem.
Old 07-14-2008, 08:45 PM   #4
liketocrawl's Avatar
Rebuild them using Team Associated's Green Slime on the o-rings and they will never leak provided you maintain them.
liketocrawl is offline   Reply With Quote
Old 07-14-2008, 08:56 PM   #5
Here she is strectching her legs.
Old 07-14-2008, 08:58 PM   #6
Holy articulation batman. Rig looks good though
jwcustomwurks is offline   Reply With Quote
Old 07-14-2008, 09:18 PM   #7
Yeah, it really suprised me too.
Old 07-16-2008, 12:57 AM   #8
teflon tape...the skinny roll, one and a half wrap on the threads. leak fixed and no scraping silicone off when you rebuild them.
drilldeep is offline   Reply With Quote
Old 07-16-2008, 01:46 AM   #9
rig looks unstable (FLOPPY)
mtnyote is offline   Reply With Quote
Old 07-16-2008, 01:55 AM   #10
Check the threads on the cartridges like said, also check the o-rings because its possible you have ruptured them while inserting the shock shaft, make a note of coating the rod end threads in shock oil or AE green slime before putting it through the o-rings
HTH
josh_smaxx is offline   Reply With Quote
Old 07-20-2008, 08:51 PM   #11
Since you've been experimenting with all kinds of oils. Rebuild the shocks using new original O-rings and 100% silicone damper oil. I've found that some oils actually cause some O-rings to shrink while some other oils cause them to swell (From personal experience I can tell you that Mobil 1 and Militec are both among oils and oil additives that can cause damage to some O-rings).
Use Associated Green Slime when rebuilding.
Check the shafts, bent or scratched shafts can cause leaks.
Locate the leak, is it where the shock shaft exits the shock body or is it at the other end?
Andsetinn is offline   Reply With Quote
Old 07-20-2008, 09:01 PM   #12
Default hey
two thumbs up for the green slime.
Best $3 I ever spent on RC.
p01rogue is offline   Reply With Quote
Old 07-20-2008, 09:24 PM   #13
They were leaking around the top threads. It seems like the RTV sealant worked good so far too. Thanks alot for the help.
Old 07-20-2008, 10:06 PM   #14
Practicing my launchs >:)
Robbob's Avatar
Permatex Liquid Teflon Sealant ....... (any automotive supply chain will carry it)
Just rebuild my plastic bodies using it, ALOT easier then teflon tape and not as tough to remove as RTV.
and with that much articulation maybe double check the bodies arent hitting anything causing the cap or body to flex, that will make the caps pop off.
Robbob is offline   Reply With Quote
