| | #1 |
| Quarry Creeper Join Date: Feb 2008 Location: EAST TN WHERE SHINE IS FREE
| ![]() ![]() ![]() ![]() torq twist is pretty much gone but i still got a little rear steer what can i do to fix it guys ? next thing i hate the droop shock set up, it just dont seem to work like it should to me. im lookin for new shocks with external set up. as i would like to try rock racing a little any thoughts on some stuff to try |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Jul 2007 Location: Portland,OR
| You need more triangulation on your lowers to cancel out the axle steer. Move the lower links to outside the shocks, as close to the wheels as possible.With the shocks inside the original axle mounts and the links on the outside of the mounts. Magically almost all axle steer will disappear Are you running internal springs for droop? Duratrax Mini Quake whites or yellows work well with 1000wt dif oil FWIW |
| | #3 |
| yes im running tcs springs do i just move the back links or front too ? |
| | #4 |
| I wanna be Dave ![]() Join Date: Oct 2005 Location: Columbia TN
| Move your lowers back out where they are suppost to be on the axles. |
| | #5 |
| IVE BEEN SZCZERBOTAGED!! ![]() Join Date: Mar 2007 Location: roland,ar
| | #6 |
| Quarry Creeper Join Date: Jan 2008 Location: pleasanton
| if you dont like the droop setup take your internal springs out from underneath the piston and put them on top of the piston. (this is what i run and love it) then the springs act just like a normal spring set up but you have no external spring. it keeps that clean look and its free just run normal 30wt oil and put a layer or two of teflon tape on the upper shock threads to keep the tops from popping off. ive never had a problem with them popping off, but i do it as a precaution. and move your lower links to right next to you shocks (both front and back). these should all help. |
| | #7 |
| | #8 |
| Pebble Pounder Join Date: Apr 2008 Location: Wenatchee
| must have alot of free time at the batch plant! lol. Thats where I get most of my wrenching done. |
| | #9 |
| Rock Crawler Join Date: Jun 2008 Location: dublin
| thanks guys i moved them out to the ends works alot better now i got to move my shock springs with your links set up this way. (out toward your wheels ) don't your links hit your edge chassis at the skid plate area ?and how about your tires at full turn ? do they rub links ? let me know...thanks ![]() ![]() [/quote] |
| | #10 |
| Pebble Pounder Join Date: Nov 2007 Location: Grand Junction, CO.
| rotate your rods on your rod ends of the links until the bends allow full turn with no rub....hope that makes sense...if it doesnt look up at rubiredunltd's pic and notice the angle of his link bends. that should help your turning clearences |
| | #11 |
| no it does not rub steering or on the chassis and yes lol i have a lot of free time here at work. that is atchley's x-trail in the background |
| Thread Tools | |
| Display Modes | |
