| | #1 |
| Quarry Creeper ![]() Join Date: Sep 2006 Location: Lake Forest
| ![]() 55T ELECTRIC MOTOR Designed exclusively for RC Rock Crawlers. Easily equip or upgrade (comes with bullet connectors. No soldering required) your AX10 RTR for more low-end pull and slower wheel speed while crawling. Specs
Part Info AX24007 55T Electric Motor |
| Sponsored Links | |
| | #2 |
| Rock Stacker Join Date: Mar 2008 Location: Salinas gang central of california
| my question is will this motor have better breaking than a leath motor? |
| | #3 |
| Axial Team Driver ![]() Join Date: Feb 2005 Location: OC
| Nice job Axial!! 55t axial motor is the same number of turns as a 55t lathe motor... I assume you mean braking, not breaking right? As in drag brake? Shouldnt be able to tell a difference. Quality of the motor looks to be the same as well, I am assuming its not handwound so drag brake characteristics should be very similar. |
| | #4 |
| 2006 2.2 National Champ ![]() Join Date: Dec 2004 Location: Driving my R/C rototiller
| I haven't had a chance to test mine out on the rocks yet. But, on a motor dyno the numbers were right there with a standard 55t motor. |
| | #5 |
| Quarry Creeper Join Date: Oct 2007 Location: PF, WI
| Any future plans to offer them in different turns? |
| | #6 |
| Pebble Pounder Join Date: Mar 2006 Location: portland
| Looks like it might be a sealed endbell type. That kinda sucks, if your brushes wear out, gotta buy a whole new motor instead of brushes. Plus its bushed instead of bearing'd, another miss in my opinion. But if the motor works well and is cheap enough, might just be easier to keep buying replacements. |
| | #7 | |
| | #8 |
| Rock Stacker Join Date: Jul 2008 Location: Orem, UT
| <English lesson> break = If Johnny breaks his new toy, will his mommy buy him a new one? brake = The brakes on my new truck work swell. drag brake </English lesson> |
| | #9 |
| RCC Addict Join Date: Mar 2005 Location: Saginaw
| Looks like the Axial site is down at the moment? :? |
| | #10 |
| Quarry Creeper ![]() Join Date: Mar 2007 Location: hartland wi
| and english lesons sux |
| | #11 |
| RCC Addict Join Date: May 2008 Location: Chicago/Bloomington
| That's, and English lessons suck. Seriously, the Axial motor looks like a nice CHEAP powerplant which should provide many hours of fun before breaking. Also, the brakes should work well with it as long as the ESC has them, brakes that is. |
| | #12 |
| I wanna be Dave ![]() Join Date: May 2006 Location: akron
| that looks like a big miss. sealed end bell, bushings, no way to tune or change springs... odds are brakes will be light most sealed endbell motors use soft springs, which give little to no braking if street price is allot less then MSRP it may be OK for a mud rig. but for anything else a rebuild able motor is the way to go.. should be nice for the RTR newbies out there. |
| | #13 |
| Rock Crawler Join Date: Jul 2007 Location: clearfield
| Its nice that Axial is putting parts out for their rigs... But.. looking at the specs of the motor, and price... i would go with an Integy lathe over the Axial... simple because its like $2 more, and you can rebuild it... |
| | #14 |
| Rock Crawler ![]() Join Date: Apr 2008 Location: Albany
| It is just a 55t lathe motor. The 55t motors were originally designed for com lathes. More torque and less rpm. Rock Crawling is a great application for this motor. Evan |
| | #15 |
| Rock Crawler Join Date: Jan 2007 Location: Secret Crawl Location Deep In England
| Ive been running an integy 55t for about 2 years and the brushes are still no-where near worn, comm still looks shiny. No big issue IMHO, maybe it is just an entry level motor? After all, Axial provide an entry level truck as well. Matt |
| | #16 |
| Rock Crawler Join Date: Dec 2007 Location: Albuquerque
| I saw this online the other day.. but as stated before, it's only two or three bucks cheeper then a Novak 55 or Integy 55T.. I think I will stick with those. |
| Thread Tools | |
| Display Modes | |
