Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: 30* Links
Old 07-15-2008, 11:04 PM   #1
Default 30* Links
So I was sitting around today after I accidentally submerged my crawler, and was thinking. Are the 30* links I'm seeing everywhere the same as the stock link, just bent? Or are they longer? If they're not longer I'm just going to bend these and see what happens, thanks!
thelmuffinman32 is offline   Reply With Quote
Old 07-15-2008, 11:16 PM   #2
The bent ones are longer but i don't know how much longer they are..
SuperBad is offline   Reply With Quote
Old 07-15-2008, 11:31 PM   #3
:-( I figured, it was worth a try.
Old 07-16-2008, 12:01 AM   #4
They are only a few mm longer. Seems like 3mm longer, but I may be wrong.
Josh87 is offline   Reply With Quote
Old 07-16-2008, 12:32 AM   #5
I think the stock lowers are 98mm and the 30° lowers are 101mm - Axial ones, that is.
Fat-Alfie is offline   Reply With Quote
Old 07-16-2008, 12:53 AM   #6
the bent ones are longer, to contain the bend and keep the same total length...if you bent the stock ones you would be shorter. simple logic.
drilldeep is offline   Reply With Quote
Old 07-16-2008, 07:31 AM   #7
Stock straights equal 12.5 wb. If you bend the stock links to 30* you will have a 12.25 wb. That is what me and a friend figured out anyway.
CrawlinClodKiller is offline   Reply With Quote
Old 07-25-2008, 08:12 AM   #8
I actually laughed out loud when i first read this. If I submerged my rig, bent links would be the last thing on my mind! All joking aside, You could bend the fronts and get longer rears to get more weight on the front axle.
chops1sc is offline   Reply With Quote
