Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: shocks and oil
Old 07-17-2008, 01:06 AM   #1
Default shocks and oil
does anybody find that their crawler has more flex if you dont put oil in the shocks? from the pictures i have seen of the other stock axials it seems like mine doesnt flex as much. i put alot of (stock) oil in my shocks, would that effect it?
siriussr is offline   Reply With Quote
Old 07-17-2008, 01:15 AM   #2
if you put to much shock oil in as the shaft goes into the shock body you may be creating a hydro lock disabling you from getting full travel.
Krawler Freak is offline   Reply With Quote
Old 07-17-2008, 03:51 AM   #3
also just because it looks stock doesn't meen it is. They ones you are seeing may be running softer axial springs.
bigflex is offline   Reply With Quote
Old 07-18-2008, 02:14 PM   #4
would it effect the crawler negatively to not have oil in the shocks?
Old 07-18-2008, 02:52 PM   #5
id try to get some softer springs....i wouldnt recommend running no oil...thats your dampner. it controls your rate of flexion and smooths out your ride. i run my oil up to about a 1/16" from the top of the body and it doesnt hydro lock out. you wont gain travel by not running any oil versus the right amount of oil as far as i know.
drilldeep is offline   Reply With Quote
Old 07-18-2008, 04:37 PM   #6
i have also found that my tires are not staying on the ground as well as some others i have seen. what is better, BB's or stick-ons? and how much weight in each tire? i have one friend who has almost a pound in each tire and that sounds like too much.
