Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: Camber all jacked, how do I fix it?
Old 07-17-2008, 11:58 AM   #1
Default Camber all jacked, how do I fix it?
The camber ont eh frontend of the crawler is all seriously jacked up. It looks like the back wheels of a VW Beetle. I gotta figure out how I can readjust the camber for this car. Can I install teh knuckes the wrong way? Meaning can the right and left side knuckles be swapped? Maybe that is the problem I have? Anyone else run into this?
Thanks
dIma
Flatty is offline   Reply With Quote
Old 07-17-2008, 12:00 PM   #2
2006 2.2 National Champ
BENDER's Avatar
The axle C's may need to be flip flopped.
BENDER is offline   Reply With Quote
Old 07-17-2008, 12:09 PM   #3
Gavyn is my BFFL
Nabil's Avatar
is it negative or positive camber?
if its negative the axle case might be cracked
if its positive swap the axle C's like bender said
Nabil is online now   Reply With Quote
Old 07-17-2008, 12:32 PM   #4
It's a solid axle, there is no camber adjustment. If your wheels are tilted then something is broken.
AreCee is offline   Reply With Quote
Old 07-17-2008, 12:37 PM   #5
That is exactly what I thought it was. Gonna go home and try and flip them.
Dima
Old 07-17-2008, 12:38 PM   #6
On all solid axles there is still a camber adj in the knuckle. With the RC car, I was guessing that the knuckles can be flipped from side to side. The problem is that they are keyed up to sit differently on each side.
DIma
Old 07-17-2008, 01:02 PM   #7
DIma
no, there is a CASTOR adjustment, no camber. Like posted above, if you have some camber in your wheel, something is broken.
mysharona is offline   Reply With Quote
Old 07-17-2008, 11:25 PM   #8
tighten the axle c screws/ my friend had this problem and the c hubs were all sloppy and made them point up more.
mauromj is offline   Reply With Quote
Old 07-17-2008, 11:38 PM   #9
... usually ball-joints.
2JSC is offline   Reply With Quote
Old 07-18-2008, 10:19 AM   #10
x2
some pictures can help figure out what is going on
wrcfan29 is offline   Reply With Quote
Old 07-18-2008, 11:27 AM   #11
a pic of what's going on might make it easier to diagnose and correct
OldShovelhead is offline   Reply With Quote
Old 07-18-2008, 11:41 AM   #12
binaryterror's Avatar
Caster is what you are talking about. This is when the axle centerline is tilted forwards or backwards.
Camber is the lean of the top of the tire. Solid axles do not have Camber adjustments, only independent suspension has this.
binaryterror is online now   Reply With Quote
Old 07-18-2008, 12:35 PM   #13
Pure Pwnage
dave56bug's Avatar
People tend to get these terms mixed up, heres a little diagram of Caster, Camber and Toe:
http://www.jeepfan.com/tech/CasterCamberToe.htm
OP said: "It looks like the back wheels of a VW Beetle." That would be negative Camber, and on a solid axle truck that means somethings broken, assembled wrong, or really worn out. As others mentioned pictures would help greatly to help diagnose whats going on.
dave56bug is offline   Reply With Quote
Old 07-18-2008, 01:31 PM   #14
It could also be Toe. On the Axial kit if you mess with the lengths of the lock out links you can set toe in/out. Also remember not only are VW heavy camber they also run some toe in.
Old 07-18-2008, 06:54 PM   #15
Linux Mint 10
JeepinDoug's Avatar
I've seen Flatty's issues.
Flatty has the correct term, CAMBER.
The steering yokes are loose on the axle, from the front, the tires look like an upside down "V".
I know one of his yoke screws are stripped, so it'll never get tight.
New axle housings Dima, or switch all the components on the axles, make the rear the front and vise versa. The bad threads in the rear with lock outs won't effect the camber issue as much.
If you flip the yokes right and left you'll have some boogered up caster, it'll look like a top fueler, at least the tie rod will be high as hell.
Mine are loose after every crawl.
JeepinDoug is offline   Reply With Quote
Old 07-20-2008, 01:39 AM   #16
Yea, I knew I was right... I am going to do what you say on Wed and swap the front and rear axles alltogether. I will see if that works, or I will tap out that front stripped hole to a fine thread.
DIma
Old 07-20-2008, 12:13 PM   #17
BigSki's Avatar
castor is very easy to adjust on these cars- run a longer or shorter upper linkage and watch the pinion angle change. The pinion is an easy to see indicator of where your castor angle is, and how it changes as the suspension cycles.
BigSki is offline   Reply With Quote
