07-27-2008, 11:01 AM | #41 | |
07-27-2008, 11:39 AM | #42 | ||
Rock Crawler Join Date: May 2008 Location: Mansfield, PA
...So is there an advantage to running the uppers strait instead of triangulated?? | ||
07-27-2008, 11:53 AM | #43 | |
Depends on what you think an advantage is There's pros and cons to all link set ups. Finding the set up that works good for you is the important part. Looks like Anthony's chassis could be set up either way. | |
07-27-2008, 06:19 PM | #44 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
well after messing around today I found out that if I put a 11mm spacer in between the chassis and the shocks the upper links will clear the shocks by a hair. I might run a 13mm spacer on each side just for more clearance. 13mm is the most I want to do, the shocks are now almost perfectly lined up with the axle mounting spots. At full flex stand still Last edited by yotachump; 02-22-2009 at 11:30 AM. |
07-27-2008, 06:30 PM | #45 |
RCC Addict Join Date: Jun 2006 Location: Sin City
Do you think a double triangulated link set up using tlt axles will work with this chassis.
07-27-2008, 06:38 PM | #46 |
what if you used the Axial angled ones (B) at the frame, the ones the stock Axial uses frame side on the uppers. then used the lower Axial mounts that drop the ball off center (A) on the rear at the plate? Last edited by Robbob; 07-27-2008 at 06:39 PM. Reason: got my alphabet wrong |
07-27-2008, 06:58 PM | #47 |
07-27-2008, 07:06 PM | #48 |
| Yea I thought about using the axial offset ends on the rear plate, but I always seem to break them. I think I have it figured out. I will see once I get to drive it.
07-30-2008, 07:12 PM | #49 |
got all the links mocked up. I might go down another hole in the rear for more AS.I also made so .461" spacers for in between the shock and chassis. I hope to have this running by next week. Last edited by yotachump; 02-22-2009 at 11:29 AM. |
07-30-2008, 07:30 PM | #50 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
Yota, I sent ya a PM about a skid and haven't heard back.
07-30-2008, 07:33 PM | #51 |
07-30-2008, 08:14 PM | #52 |
Rock Stacker Join Date: Feb 2008 Location: Minnesota/Wisconsin
awesome build and amazing quality on the parts I wish I had the money and skills to do a build of this caliber keep up the good work |
07-30-2008, 08:40 PM | #53 |
07-30-2008, 08:57 PM | #54 |
Ive read almost all the threads about AntiSquat and I dont want to jack the thread in that direction. This is more of a question about why you like so much AS? I prefer almost none but being new Id like to hear what you feel it gives your vehicles. Im watching all your prototype builds and am wagering between your rig and another one around here so Id like to hear personal preferences. thanks |
07-30-2008, 09:29 PM | #55 |
Rock Crawler Join Date: Mar 2008 Location: Arizona
Looks real good! I am a big fan of your rear four link mount and would like to see the differance betwwen the paralle upper and triaglelated. |
07-31-2008, 06:24 PM | #56 |
Well Im almost finished with it. Threw some old wheels and tires on it for mock up. I have some Mayhem Wheels on the way . As you can see there is a hollow puller on there, I dropped it and bent the pinion shaft. The puller will fit but is REALLY TIGHT. If you are going to run a Puller you need to run a 14t or lower pinion and file the rear of the puller, to make it fit. I am going to try to relocate the Dig servo tomorrow. 3 1/8 of ground clearance Its a little tall for me I think, Im going to adjust the shocks later. Last edited by yotachump; 02-22-2009 at 11:29 AM. |
07-31-2008, 06:32 PM | #57 |
ΜΟΛΩΝ ΛΑΒΕ Join Date: Dec 2006 Location: In tha Bush of Louisiana
Haven't I seen this chassis before ? Looks great |
07-31-2008, 08:20 PM | #58 |
I wanna be Dave Join Date: Oct 2004 Location: QC-AZ
That will never work |
07-31-2008, 10:28 PM | #59 |
08-02-2008, 01:27 PM | #60 |
well I didnt get much done yesterday, I just relocated the DIG servo and setup my shocks. For the dig servo I just took off my old home made servo mount and drill 2 new holes in it and bolt it right up. I got it nice and low about where I wanted it.Everything clears nicely. As for the shocks, Since they are Revo shocks they are valved really slow, So I drilled out the piston holes with a #55 drill bit.Im running 50w in the rear and 35w up front. Last edited by yotachump; 02-22-2009 at 11:29 AM. |
