08-10-2008, 05:40 PM | #81 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
I just got my new wheels and tire mounted. So here are the pics.sorry that the pics are crappy. Im am not using my Dig right now because I have to relocate the servo that is why its unplugged. So for now the Specs are: Axial Axles Bonus Line Lockers Axial Cvds Axial HD Ring and pinion RCP Straight axle adapters RCP Straight axle shafts RC4WD Knuckles RC4WD C'c Axial Tranny VF DIG Axial Slipper Clutch Hot Racing Aluminum tranny Gears Airtronics 94358 Dig servo Hitec 5955 Steering servo Revo Shocks (valves drilled) and yellow jato springs CDW 1.0 Chassis CDW upper link Plates Mayhem Wheels M2 Badland Tires 45t motor Thunder Power 1320 11.1v lipo Mamba Max CC BEC DX3R Last edited by yotachump; 02-22-2009 at 11:33 AM. |
08-10-2008, 06:24 PM | #82 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
How long are your upper and lower links? Also do you know of any off the shelf links that would work or am I gonna have to make my own?
08-10-2008, 06:58 PM | #83 | |
The upper links all depend on what hole you mount them on, on the chassis. For me the rear uppers 85mm, I am using a 55mm+30mm axial post mounts. For the fronts I am using 70mm axial post mounts(because I am using the Battery/servo mount they are shorter).Both front and rear UPPERS are using REVO SHOCK ROD ENDS. I really like the Revo shock ends, they take 3mm thread and are super strong.Traxxas part #5469, they don't come with balls, I am using the balls that came with my standard revo rod ends. I cant remember how long my lowers are right now.I can get a measurement tomorrow for you. | |
08-11-2008, 09:27 PM | #84 |
What is your belly clearence on your setup?
08-11-2008, 09:56 PM | #85 |
08-11-2008, 09:58 PM | #86 | |
Got pleanty of locked diffs or spools. Just need 1 factory diff case that ain't been glued/welded | |
08-11-2008, 10:56 PM | #87 | |
CDW for Mrs. LIKES2CRAWL Last edited by LIKES2CRAWL; 08-11-2008 at 11:06 PM. | |
08-14-2008, 10:00 AM | #88 |
Any action shots yet?
08-14-2008, 10:02 AM | #89 |
| Been super busy, I haven't even had time to paint my body, I got it cut out but just need to paint it. Im also waiting on some springs, they should be here today. So maybe on Saturday ill have some pics up. Last edited by yotachump; 08-14-2008 at 10:10 AM. |
08-14-2008, 02:49 PM | #90 |
You drilled out the holes in your shock pistons right? What size did you drill them with and what weight oil you running? I have the stock pistons and 50 weight oil and it compresses and retracks realy slow.....maybe to slow. |
08-14-2008, 09:10 PM | #91 | |
Guess you didnt read post #60 I drilled out the pistons with a #55 drill bit and I am running 35w up front and 50w in the rear. The yellow jato springs see a little stiff for my liking.I just picked up some 2.7lbs springs now that I will be testing tomorrow. Last edited by yotachump; 08-14-2008 at 11:58 PM. | |
08-14-2008, 09:14 PM | #92 |
Got some lower links drawn up for this the other day. I should see them in about four weeks. I was originally going to make them without holes but the machine shop needed the holes for easier setup purposes.Come to find out after FEA tests that the holes make the links stronger. Last edited by yotachump; 08-14-2008 at 11:57 PM. |
08-15-2008, 02:57 AM | #93 | |
08-15-2008, 03:44 AM | #94 |
RCC Addict Join Date: Jun 2006 Location: Durham, NC, USA
show some videos
08-15-2008, 11:35 AM | #95 |
08-15-2008, 03:48 PM | #96 |
| I don't own A video Camera. My digital camera does record though, But im not sure how good.Maybe ill see how good it works. Tanis posted a Video.But the truck hes running Definitely needs so weight in the tires. CDW Proto chassis |
08-15-2008, 04:55 PM | #97 |
Finally got the new body painted. These are the only 2 pics that came out OK. Ill try to get some action pics up tomorrow. Last edited by yotachump; 02-22-2009 at 11:32 AM. |
08-15-2008, 06:42 PM | #98 |
I wanna be Dave Join Date: Oct 2004 Location: QC-AZ
Looks good But when are you going to trim the body and how do I get some of those stickers?
08-15-2008, 11:07 PM | #99 |
08-15-2008, 11:46 PM | #100 |
RCC Addict Join Date: Jun 2006 Location: Sin City
Looks good Anthony, Now you need to tint your windows
