| | #1 |
| Beef Tube Supplier ![]() Join Date: Jul 2008 Location: Southwestern, Ohio
| What is the optimum ride hieght for an Edge chassis with an internal spring setup? I am running TCS meduim springs - Full spring under piston, half on top. IMy GC is right at 2.5 inches with this setup and seems a little low. Thanks! |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Feb 2008 Location: Lagrange
| My ride height was 2.5 with the edge also. |
| | #3 |
| Quarry Creeper ![]() Join Date: May 2008 Location: Mansfield, PA
| Im at about 2.5" of GC...but the bottom of my rig is completely delrin so it doesn't really matter I personally wouldn't want mine to be any higher than 2.5". (I run full droop susp) Find the best height for YOUR specific setup. Last edited by Trugg; 07-18-2008 at 05:29 PM. |
| | #4 |
| Rock Crawler Join Date: May 2007 Location: lacey
| if it seems too low, raise it. if it seems too high, lower it. there is no "perfect" ride hight, it is all in the experimentation. this answer is also good for shock oil, tire weight, tires, chassis, wheels, shocks, springs, gearing, batteries, you get the point. EXPERIMENT! Good day |
| | #5 |
| Rock Crawler Join Date: May 2008 Location: ************************ Why crawl, when you can just jump up there?!
| Sprung and a edge... my buddy got scored great at our last comp and his was set at 3". 2 7/8" is my rigs sweet spot. Good Luck |
| | #6 |
| How do I raise it? Do I add longer springs to the top off the piston. Right now I am running 1/2 of a spring on top. |
| | #7 |
| Rock Crawler Join Date: Jun 2008 Location: Lemont, IL
| im right at 2.5in. had a little hang up at the comp today, but i like it |
| Thread Tools | |
| Display Modes | |
