Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: I would like everyones opinion...My first Crawler
Old 07-18-2008, 05:56 PM   #1
Beef Tube Supplier
biggin69's Avatar
Default I would like everyones opinion...My first Crawler
I just finished building my first crawler. Let me know what you think - Questions, Comments, Complaints, or Compliments Accepted.
biggin69 is offline   Reply With Quote
Old 07-18-2008, 06:07 PM   #2
love the all black theme, mabey paint the beadlocks black too.
get some tires you will be amazed on how much better it will crawl than with the stock tires.
what springs are you using in your shocks?
yoda316 is offline   Reply With Quote
Old 07-18-2008, 06:10 PM   #3
i would sugest panthers or losi rock claws
Georgerm is offline   Reply With Quote
Old 07-18-2008, 06:19 PM   #4
Location: ************************ Why crawl, when you can just jump up there?!
Looks good. Try out some claws. It looks like those claws would be perfect for that rock surface. You already running a slipper?
ADDICT is offline   Reply With Quote
Old 07-18-2008, 07:07 PM   #5
nice rig. i agree paint the beadlocks black too.
what kinda of body is that?
did you buy or make it?
if you bought it where at?
CrawlHer is online now   Reply With Quote
Old 07-18-2008, 07:16 PM   #6
get something better than tape to mount your batteries. even zip ties would be better. black out your tie rod and drag link, your upper links, and your rock rings. try some other tires. and have fun....
mtnyote is offline   Reply With Quote
Old 07-18-2008, 07:23 PM   #7
I think it looks cool. My only suggestion would be to replace the socket cap screws with button heads on the lower link mounts. And/or move them inside the frame. When mine were like that, they snagged on everything.
FL Knifemaker is offline   Reply With Quote
Old 07-18-2008, 08:12 PM   #8
looks good ! what is your gc on your edge ? what shock set up ? springs oil weight , spacers , etc. ? how long of running time are getting out of your battery set up ? thanks. keep crawling!!
ROCKCAD is offline   Reply With Quote
Old 07-18-2008, 08:49 PM   #9
liketocrawl's Avatar
Schweet!! Maybe consider mounting your esc on the Y link and your rx on the underside of the hood? Happy Crawln
liketocrawl is offline   Reply With Quote
Old 07-18-2008, 09:10 PM   #10
thats really nice. especially for a first rig.
bigflex is offline   Reply With Quote
Old 07-19-2008, 07:15 PM   #11
Beef Tube Supplier
biggin69's Avatar
Thanks Guys! It makes me feel like I did something right getting all of the feedback. I will try too answer all of you questions with this post:
yoda316, I am running TCS medium springs - 1 spring under piston, 1/2 spring on top.
Georgerm, I plan on getting a set of Losi tires soon.
rtooyak, No, that is the stock setup on the spur.
CrawlHer, I made the body panels myself. I cut them out of .040" lexan and then painted the outside with flat black Fusion paint.
mtnyote, I plan on doing all of that soon. I have a wife that I must give some attention to every once in a while.
FL Knifemaker, I tried mounting them inside and did not like it. I will probably change the screws as you suggested.
ROCKCAD, GC is 2.5" (I would like it to be 2.750"), spring setup mentioned earlier, shock oil wieght is 60, stock shock limiter moved to the inside, run time is still yet to be determind as I have run it about 45 minutes and it still has a charge.
liketocrawl, Why do you suggest this?
bigflex, Thanks!
To answer some of the other questions, I do plan on blacking the entire thing out. Do I need to strip the green or just paint over it? I ran out off zip ties so I used the battery strapping tape from my carpet car just to get up and running. I am hoping to find some fellow crawlers to share thier secret crawling spots. The pics were taken at a local constrution site. I NEED SOME ROCKS!
Thanks Again Fellow Crawlers
Old 07-19-2008, 10:24 PM   #12
bigflex, Thanks!
So that all the weight is up front and you can remove the battery mounts. Just a thought. Nice addition to the cage
Old 07-20-2008, 01:29 AM   #13
Looks pretty nice!
Devinb is offline   Reply With Quote
Old 07-20-2008, 02:17 AM   #14
just spray your green aluminum with oven cleaner and let it sit for 20 minutes then rinse. green-b-gone
