suspension ? ok! iv`e been told that the scorpion needs to be lowered to around 2.5" thats like .75" lower than stock. my ques. is how much spacer do i use in the shocks? and what weight oil? i have been thinking and if you shorten the shock you will also be increasing the preload on the springs. i have red, green and the stock blue springs, wich ones should be used for proper articulation? thanks in advance8) |
"proper" is up to you. Test them all and see what you like. Read the AX-10 comp-prep thread. It has all the info you need... but to answer your Q: use the stock shock bumpstops, but on the iside if the shock body to lower the CG."thumbsup" |
use red on the 3 shocks and maybe the stock springs on the torque twist corner. hope this help. i ran 30 weight on the 3 and 50 on the left rear corner. |
