08-05-2008, 01:38 PM | #21 |
Rock Crawler Join Date: Jan 2008 Location: Vancouver, BC, Canada
thats one really nice looking crawler post some action pics |
08-05-2008, 03:01 PM | #22 |
Nice job on he MFM Black Widow John. That's one well crafted and clean machine and dead sexy.
08-05-2008, 06:09 PM | #23 | ||
Thanks. I hope to get it on the rocks this weekend....possibly with some video. Thanks...now all it has to do is perform Last edited by Offroader5; 08-05-2008 at 06:12 PM. | ||
08-05-2008, 09:18 PM | #24 |
Well, I have the body mounts & body done for it...at least till I can find a comp body I want and get it painted. I ended up using my still brand new OEM blue WK body. I removed all the stickers and repainted the window areas and the "bed cover" flat black on the outside, then added a couple new stickers. Did some major surgery also to keep it realllly low. Sorry, no pics tonight...I'll shoot some tomorrow night. Think I am going to ditch the Sidewinder in lieu of my MM, and I also have a couple battery packs on the way to fit it just right. |
08-06-2008, 08:15 PM | #25 |
Here she is. All ready for it's first comp/gtg. Going to give 'er a shot this weekend. Flexing a bit more than I think it needs, but we'll see how it does. I may change over to Revo shocks with longer lower rod ends and see if that nets a bit less droop. Isn't that body gorgeous (I need vendors to send me more stickers :-P) |
08-06-2008, 09:08 PM | #26 |
Rock Stacker Join Date: Jul 2008 Location: Battle Ground, WA.
WOW!!! That thing is awsome!!!!!!! |
08-07-2008, 02:57 AM | #27 |
RCC Addict Join Date: Feb 2008 Location: Nevada
That crawler looks sweet Looks like it will do well on the rocks also |
08-07-2008, 10:48 AM | #28 |
RCC Addict Join Date: Feb 2008 Location: Hiatus..sutiaH
Simply gorgeous! Can I say that about a toy, lol. Really great build!
08-08-2008, 03:25 PM | #29 |
08-11-2008, 12:12 PM | #30 |
Any update of last weekends try out?
08-11-2008, 03:47 PM | #31 |
Quarry Creeper Join Date: Jul 2008 Location: us
lookin good
08-11-2008, 08:54 PM | #32 |
Well, not everything went as smoothly as I had hoped this weekend. First, I realized how important dig is when you only have the one steering axle Second, it's a bit tougher to wheel your rig through someone elses route instead of your own. Third, I found that the Hot Racing rear straight axle shafts are weak Took a nice roll off of a 3 to 4 foot ledge and landed right on the rear tire with a loud thud. After picking up the rig, I noticed the wheel wasn't straight any longer. The fall had bent the shaft right at the weak point...where the hole is for the wheel hex cross pin. I was able to bend it back to finish up the course, but at that point it was now weaker which meant it didn't last much longer and I was unable to continue on to the other course. I think once I get the dig in, the shocks on it that I wanted to put on it (with the right oil), and junk the HR rear lockouts in lieu of the MIP CVD's and knuckle lockouts....I'll be much better off. Here's a couple pics.....thanks to SamuraiAZ |
09-04-2008, 03:34 AM | #33 |
Quarry Creeper Join Date: Mar 2007 Location: hartland wi
so any updates on this rig???
09-04-2008, 06:08 AM | #34 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
Offroader, I am running a sprung blackwidow. I dont know how you feel about sprung as apossed to droop, but my losi sprung bw is amazing! I noticed is some of your comp pics how your rig was leaning hard on climbs. Just something to consider. |
09-04-2008, 09:02 AM | #35 | |
Hey OffRoader, did you see my thread about mine being finished finally?! | |
09-04-2008, 06:42 PM | #36 | ||
| Well, it is "done"...but I do have some changes I want to do since seeing it perform in it's first comp. -Swapped out the servo for the 5955 I had (wanted a bit more torque). -Installed a CC BEC to handle the new servo nicely. -Swapped out the Traxxas shocks for the Prolines I had (with the right oil in them this time ) -Got rid of the weak HR rear straight axle...and right now just have the stock knuckles back on and locked out. -Buying CVD's here pretty quick. -Swapped the Axial trans outputs over to the CDW 6mm. -Swapped out the Axial axle pinions for WK's to get the 6mm and hole through the shaft. -Still need to pick up a DNA dig for it. -Swapping over to 32 pitch gearing (HH Cobalt likes to eat the 48p ones') Quote:
I'm not totally opposed to sprung...I try something different it seems every time I touch one of my rigs. Quote:
....'bout time.... | ||
