08-02-2008, 04:38 PM | #1 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
| 96 tooth Spur gear for Axial Transmission?
I have the Crawler Design Works 6mm outputs from yotachump and I am looking for the 96 tooth spur gear. I have been to RCP, TCS, and JP customs website and cannot find a 96 tooth, 48 pitch spur gear for the Axial transmission. I have seen pictures of the CDW 6mm output with a 96 tooth spur gear and wanted to know what brand people are using and where they are purchasing them. I searched the AX-10 section and came up with nothing on this specific topic. Thank you in advance for any help.
08-02-2008, 04:55 PM | #2 |
Rock Crawler Join Date: Oct 2007 Location: Grants Pass
The one I am using was from kimbrough
08-02-2008, 04:59 PM | #3 |
You could also try this adapter: http://www.3racing.hk/products.php?products_key=3110 Then you could use any 48p spur gear like the Traxxas or HPI's Just another option. |
08-02-2008, 07:56 PM | #4 |
RCC Addict Join Date: May 2007 Location: pasadena, tx
08-02-2008, 07:59 PM | #5 |
Moderator Join Date: Jul 2007 Location: Texas baby!
X3 for Kimbrough |
08-02-2008, 08:48 PM | #6 | ||
| Quote: Quote:
I am trying to gear down as much as possible on my next project. I will be using a Holmes Hobbies brushless crawlmaster with a 3S lipo and I want to avoid cogging as much a possible. Thank you for the responses. | ||
08-02-2008, 09:31 PM | #7 |
Newbie Join Date: Jul 2008 Location: Outside Champaign
I tried using a Kimbrough 93 tooth, it didnt clear the drive shaft yoke, I had to fall back to a 90 tooth Kimbrough. I looked into going to T-Maxx drive shafts and that was even worse for clearance, so I am giving modified (stretched with pieces and threaded rod) Stampede shafts a try. I already mangled one stocker. |
08-03-2008, 09:25 AM | #8 |
Quarry Creeper Join Date: Jun 2008 Location: phx
I have a 93 and 96 tooth spur from servo city. I can only get the 93 to fit w/o hitting the driveshaft. How do you get a larger spur to fit? http://www.servocity.com/html/48_pit...__200__fa.html |
08-04-2008, 09:58 PM | #9 |
08-05-2008, 11:13 AM | #10 | |||
Quote: Incidentally, I ordered two of the 96 tooth Kimbrough spurs | |||
