08-11-2008, 06:53 PM | #1 |
Newbie Join Date: Aug 2008 Location: Illinois
| droop suspension
since i have built my ax10 about three weeks i have been running a shock combination i have not seen on here but i might have missed it. From the beginning I have been using a tcs edge chassis with the internal shock spring everyone runs, but on the outside i have also been running the standard coils. I have really loved this setup, give the suspension and nice even feel. So just a few minutes ago i decided to try a droop setup and took off the outer coils. Wow, what an aweful thing. why do those of you that run it love it? it has no downward force on the axle. Oh i am also running bent links from the outer position, if that makes a big difference.
08-11-2008, 08:38 PM | #2 | |
Rock Stacker Join Date: May 2008 Location: united states
I think its a personal preference. I love my droop setup. It takes a lot of trial and error to get one setup correctly. Everybodys is different depending on rig weight , oil used, springs ,shocks, chassis. That brings me to something else , I have a custom chassis that was made specifically for Revo shocks in a droop. I love the LOW center of gravity , and I prefer the way it drives. If you really want to try droop you will have to get one setup properly before you can see the benifits . oh and BTW...it climbs like a mofo | |
08-11-2008, 09:05 PM | #3 |
Newbie Join Date: Jul 2008 Location: BC
I am also running droop with a lot of success. It stays so close to the surface when climbing steep grades. What oil are you using sulfur?
09-05-2008, 06:50 PM | #4 |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
I'm searching for Droop setup, but not much here How exactly is this done so far I heard to run internal springs to force spring to compress Thinking out load: I understand things are different depending on HEIGHT, Weight, OIL Weight and if full dropp or 3/4 droop. so that means put short spring above or Below piston shaft inside ? Any advice for 1.3 lb chassis (like a Hustler) 18" super with front Droop with 1.2 travel shock Thanks |
09-05-2008, 07:07 PM | #5 |
Newbie Join Date: Feb 2006 Location: Kingman
I'm running droop in the front. It climbs like a goat! It realy is all about the setup. My rig just took a spill off the top of an 8 foot boulder, and pulled the shock apart. I knew the stock Axial plastic shocks were kinda weak, but know I have an excuse to put those Losi shocks on. Do you have any pictures of your Edge? Post up |
09-05-2008, 07:08 PM | #6 | |
Newbie Join Date: Sep 2007 Location: CO
Its called gravity On a serious side. I run semi droop on the back, and full sprung on the front at the moment. Works well for me, but Im far from a competitive crawler. On the back I first tried all droop with just 20wt oil, but my belly height was a bit to low for my liking. I went down to my local ACE hardware and bought some small coils and put them inside the shock body and put the stock outer coils on. Plenty of flex for me, keeps the back low, while still having a decent belly height. At some point the front will be done as well. | |
