Thread: help a noob
Old 08-12-2008, 03:45 PM   #1
Default help a noob
i have a futaba sport radio system esc and s33o5 metal gear servo. integy v10 55t motor.Ive got axle plates for split packs. stock stick pack connecter that im willing to doaway with. dont want to burn nothing up but.willing to spend 100 on charger bat and con maybe a little more. i used the serch button but it confused the hell out of me
hardhead is offline   Reply With Quote
Old 08-12-2008, 04:20 PM   #2
www.tcscrawlers.com has a six cell split pack for $20.99. They also have a MRC 960 Brain charger for $48.99. I suggest you get deans plugs and use them to connect everything. Put female on the battery and motor, then put male on the speedo and charger. When the plug is flat on the table, solder the red wire to the verticle tab. Here's some advice I learned the hard way; use a pair of pliers held closed with a rubber band to hold the plug. Deans plugs have the same resistence as an equal length of wire and are easier to connect and disconnect than bullet or tamiya connectors.
tanmonster is offline   Reply With Quote
Old 08-12-2008, 04:49 PM   #3
im wondering if i can run 8.4 or is that to much 7.2 the most i can run
Old 08-12-2008, 05:10 PM   #4
I dont know much about that esc but id stick with a 6 cell. I like the traxxas plug better because theres more surface to unplug them(grab on to)
life_livin is offline   Reply With Quote
Old 08-12-2008, 06:51 PM   #5
I agree but I had deans plugs before traxxas came out with that plug. I have heard great things about the traxxas plugs. (a.k.a. theyhave no more resistence than deans) Don't get a seven cell unless you KNOW the esc won't fry. With a 35 turn motor six cells is plenty of torque and wheelspeed. Actually, a 35t makes more torque on 6 cells than a 55t. Apparently, it all has to do with amp draw; the 35t drawing more amps than the 55t. 55 turn motors don't make full power until about 10 volts.
Old 08-12-2008, 08:43 PM   #6
The convention should be to use female connectors on power SOURCES to minimize the potential for short circuits. It also prevents mixing up the speedo motor & battery connections.
Thus female on the battery and speedo output (to motor)and male on the speedo input (from battery), motor, and charger.
The charger is the only departure from the convention, as we need to put power into battery before we can get it out to run our crawlers!!!
Narly1
Narly1 is offline   Reply With Quote
Old 08-13-2008, 04:32 AM   #7
thanks guys
