![]() | #1 |
Quarry Creeper Join Date: Jul 2008 Location: Stuck in Missouri for now.
So I got this wonderful ESC for like $8 off E-bay and dropped it into my ARTR just to have a functioning ESC in the mean time. But now I have an issue that I can't seem to crack. It worked for about an hour or so but now the ESC only works in reverse. I have rechecked all the connections running from the ESC, the RX, and the motor, and everything is correct. I run a 2216 Traxxas RX cuz it was cheap and the ESC indicates that it is getting signal, it just not switching to reverse. Integey 55T motor Axial AE-1 ESC Traxxas 2216 3 channel RX Futaba S3305 Servo 2s2p 8k 15c lipo Thanks in advance for the help. |
![]() | #2 | |
Newbie Join Date: Jan 2010 Location: Australia New South Whales
| ![]() Quote:
i am posative that you cant use lipo batterys with it in nicad's and ni-mh batterys so you could have killed it by using lipo batters on it. | |
![]() | #3 |
Quarry Creeper Join Date: Feb 2009 Location: In my house
They are strange, some times, for no reason at all, they will change settings. They will switch direction, or go to FORWARD/BRAKE/NO REVERSE, or they just will not arm. I have found 8 out of 10 times just reseting them fixes it, 2 out of 10 times it will need to be reprogrammed. PS: they are not set up for LiPo (no cut off) but you can run 2S and 3S LiPo's through them no problem. |
![]() | #4 |
Rock Stacker Join Date: Aug 2010 Location: Winnipeg
![]() | #5 |
Pebble Pounder Join Date: Jun 2010 Location: pelham
my guess is either you killed it with the lipo or you wasted 8 bucks and someone riped you off and sold u a broken esc
![]() | #6 | |
RCC Addict Join Date: Apr 2009 Location: United States of the Offended
| ![]() Quote:
Stock esc vs 2s lipo... | |
![]() | #7 |
cherry bomb ![]() Join Date: Jul 2006 Location: Nanaimo, BC, Canada
I ran 2S lipos on my stock ESC till I upgraded, and the same ESC still see's lipo use in my other car. to the OP, i'd try reseting like has been said, not much can go wrong with these things, but if its not a simple fix it was unfortunatly, likely a bunk ESC from the get go, good luck anyawy. |
