08-24-2008, 09:59 PM | #1 |
Newbie Join Date: Jul 2008 Location: Pflugerville
| AX10 Drive Shaft Issue
So I'm crawling up a huge rock and once again I hear a snapping. I thought it was the wheel hexes until I checked closer and saw that the drive-shaft was twisting inside itself and popping, and whenever I got good traction that would happen. I bought a couple new Traxxas drive-shafts, but I was wondering if anyone has had this issue before and if anyone knows of any aluminum drive-shafts are available that will work with the AX-10? I'm close to being comp ready...real close... |
08-24-2008, 10:04 PM | #2 |
Rock Stacker Join Date: Jul 2008 Location: Under A Rock
Get MIP CVD'S !!!!!
08-24-2008, 10:07 PM | #3 |
Quarry Creeper Join Date: Apr 2008 Location: Alexandria
Get a set of the MIP driveshafts. One of the most important mods on an AX-10 IMO. If you're going to run dig, you can get the set with a shortened rear driveshaft from Thunder Tech that will fit with a dig unit like the VF Dig.
08-25-2008, 08:58 AM | #4 |
Newbie Join Date: Aug 2006 Location: Muskegon
I busted a yoke within 5 minutes of running my AX for the first time. I am buying the MIP drive shafts.
08-25-2008, 09:19 AM | #5 |
Thanks...I'll look into those...
08-25-2008, 09:26 AM | #6 |
Rock Crawler Join Date: Aug 2008 Location: Strugglin
MIP strong as hell
08-25-2008, 09:45 AM | #7 |
Newbie Join Date: Aug 2008 Location: Fremont
I purchased the MIPs, but I have a problem. The pins keep slowly but surely sliding out, I've tightened the allen screws pretty tight (although, not as tight as possible). Should I disassemble them a reassemble as tight as possible?
08-25-2008, 09:56 AM | #8 |
Yes. Clean off the grease if you got it on the screw threads both on the set screw and the screwhole. Then use Blue Loc-tite to hold the screw in place after you tighten it down.
08-25-2008, 10:24 AM | #9 |
to all you guys with the MIP shafts... Are you breaking anything else in your driveline? How long and how hard have you been running these MIP shafts? |
08-25-2008, 10:34 AM | #10 | |
I've read where some use shrink tubing to keep this from happening. Find the right size tube, shrink it down with heat, and trim. Also, these shafts a lighter than the punisher shafts. Just thought I would add that. | |
08-25-2008, 11:33 AM | #11 |
Quarry Creeper Join Date: May 2008 Location: ncrccrawlers.com
I havent broken anything yet but I believe the tranny outputs are the next weak link. Mine are looking rough where the set screw tightens down. I didnt dimple the outputs to keep the yolks on either. I thought it would make my situation worse. But if anything breaks/fails.........it needed upgrading anyways. |
08-25-2008, 12:49 PM | #12 |
Rock Stacker Join Date: May 2008 Location: oregon city
yea it goes tranny outputs then tranny gears. i have broken all and it was not that hard either |
08-25-2008, 01:07 PM | #13 |
Rock Crawler Join Date: Jul 2007 Location: central PA
Mips are a possible choice. But, for about 10-15$, I was able to convert my Axial's driveshafts to parts from the Revo and Tmaxx The Revo shaft out back serves great for a VF/DNA dig because there is NO twisting whatsoever and it allows a smooth telescoping action. |
08-25-2008, 02:04 PM | #14 |
Newbie Join Date: Jan 2007 Location: Washington DC
| weak link
Installed MIPs and broke the trans outdrive in no time.
08-25-2008, 03:59 PM | #15 |
Pebble Pounder Join Date: Apr 2008 Location: In a state of eternal chaos
There is another choice. Punisher shafts from RC4WD. |
08-25-2008, 05:33 PM | #16 |
Rock Stacker Join Date: Feb 2007 Location: Roseville, Ca
08-25-2008, 05:57 PM | #17 |
Pebble Pounder Join Date: Oct 2006 Location: Mt. Enterprise
where can i buy these mip shafts?
08-25-2008, 06:17 PM | #18 |
Quarry Creeper Join Date: Jul 2008 Location: Galt
08-25-2008, 07:26 PM | #19 |
ok, thought so thanks!
08-26-2008, 07:43 AM | #20 |
hmmm I think I'd rather have my $3.00 pede drive shaft break than something in the tranny.
