Thread: TMaxx shock mod
Old 08-25-2008, 10:41 PM   #1
Default TMaxx shock mod
I searched but I couldn't find it...
Is there a mod for the Tmaxx shocks to use on the AX10 so you don't lose the suspension travel because the Tmaxx shocks are shorter? I think it has something to do with the caps - but I can't find any details anywhere. Help? Links?
JimO
Erie, PA
JyymBo is offline   Reply With Quote
Old 08-26-2008, 12:11 AM   #2
You can use dubro monster 3mm rod ends for extra length..
or
Cut the shock mount off the top cap and drill a hole in the center and then put a regular rod end on it...
SuperBad is offline   Reply With Quote
Old 08-26-2008, 02:22 AM   #3
what i did was, use the shock shafts from the axial in the shock body of the maxx. perfect fit
douwe is offline   Reply With Quote
Old 08-26-2008, 02:46 AM   #4
if you make a cantilever type suspension you can actually get almost twice the travel of the stock maxx shox some what like this
and i get pretty good articulation with it set up like this
Mr. crawl is offline   Reply With Quote
