09-09-2008, 03:17 PM | #21 |
Rock Crawler Join Date: Mar 2008 Location: Arizona
I run a slipper in mine but I run 14t pinion and a 83t spur (platic) on 45t motor on 4s lipo I do not break drive shafts with this setup. The metal to metal will be louder.
09-09-2008, 03:30 PM | #22 |
Rock Crawler Join Date: Aug 2008 Location: Strugglin
| britcrawler
im asumming you went with the 89 HR spur gear what pinion did you use.and how much did the combo slow you down
09-13-2008, 12:53 PM | #23 |
Pebble Pounder Join Date: May 2008 Location: Two Harbors, MN
I used to have the same problem. I run a bm-9 brushless with a mamba 25. The cogging drove me crazy. I was running a 12p with 87 spur which just rubbed my drivshaft rings at full articulation. To solve this problem check out cdw outputshafts http://www.rccrawler.com/forum/showt...&highlight=CDW you can run a 96t spur from kimbrough and still have room. I have a set of the 6mm and they rock |
09-13-2008, 01:38 PM | #24 |
Pebble Pounder Join Date: Jun 2008 Location: UK
I'm currently using the 12T Hot Racing Pinion. You have to use the supplied spacer plate on the Axial to clear the coloured 'shank'. It can make assembling the motor on the transmission 'interesting'. It works real well though, I've got bags of torque now and it's still fast enough at full beans to give a good wheel speed burst. Just gotta sort out my torque twist now but I've got a solution on the way for that from East End Machining.
09-13-2008, 07:27 PM | #25 |
Quarry Creeper Join Date: Jun 2007 Location: Inthe back of JACK IN THE BOX!!!!
Well i run a 89 hot racing aluminim gear and a 55turn motor a 20 tooth pinion 3s lipo 11.1 volt, i have more than enough wheels speed and tons of torque. I don't break shafts becouse i used the slide locks to keep the shafts ears in there place. |
