09-02-2008, 03:45 PM | #1 |
Newbie Join Date: Aug 2008 Location: Illinois
| Rear Steer
so i want rear steer on my axial. I don't care about comp, so a dig is out of the question. Nothing is cooler than rear steer. What is best route controller wise? I was looking at a Futaba 3PM with FAST 2.4 ghz. I sure you guys will say spectrum. I am not spending more than $200 on a controller if possible. I have also rear about a punk 4ws steer controller. what is that and where do i get one. With rear steer is there a device that will allow me to steer indepently. I want to be able to steer both opposite and same of front tires.
09-02-2008, 05:02 PM | #2 |
Rock Stacker Join Date: Feb 2007 Location: Roseville, Ca
my jr xs-3 does that. does 2ws, 4ws, and crab. just gotta push one or two buttons to switch between the 3.
09-02-2008, 05:19 PM | #3 |
RCC Addict Join Date: Feb 2006 Location: ccxc
I have that radio...works great. One switch and u go from 2ws to 4ws and another button you can crab walk
09-02-2008, 05:42 PM | #4 |
Quarry Creeper Join Date: May 2008 Location: Hartsville, SC
all you need is a 3 ch. radio and receiver. The only thing is the 3rd. channel switch has to be a 3 pos. switch. I've got a Jr sport XR3 FM. NOT THE XR3I it only has a 2 pos. but there are lots of them out there. You could go with the traxxas tq3 with the 3 pos. mod. You can pull one of those off for about 40 bucks and most people like them. But I believe they are AM. Possible exessive glitching. But the XR3 is my recommendation.
09-02-2008, 11:24 PM | #5 |
Pebble Pounder Join Date: Jul 2008 Location: kelowna
I'd say if your spending the money on a controller may as well bite the bullet and get something that will support whatever you want to do. 3 channel is not enough IMO. You want rear steer and dig, not a choice between them...why limit yourself to just one. Later when you realize that clod style axles are way better then driveshafts and a transmission you can go independent front and rear throttle control. That is actually WAY better then a 3pos dig. If your going to stick with the hobby I would say invest in a good 4+ channel TX. You can get a DX7 (7 channel) for $300 and the difference between it and the 3ch radios is night and day. |
09-03-2008, 05:17 AM | #6 |
hmm i do like the price and all the features but i'm not sure i'm a twin stick kind of guy. Also what are the dimensions of that thing? it looks huge.
09-03-2008, 10:29 AM | #7 |
Its not that big. In fact its considerably smaller then the dx6i. If I had to guess 8" x 6" not counting antenna. Sticks allow for much more throttle precision then a gun.
09-03-2008, 11:56 AM | #8 | |
Quarry Creeper Join Date: May 2007 Location: Seattle
Pro's ... Inexpensive. - good for crawling as your not as worried about getting it a little dirty. Does what you want (2ws, 4ws, 4w crab.) Long battery life. It's on 2.4ghz. Con's ... Hard to program, Futaba and "intuitive" do not go hand in hand. ..thats all I can really think of...you'll want to hang onto the manual for this one. | |
09-03-2008, 05:41 PM | #9 |
Rock Stacker Join Date: Jun 2008 Location: On Canada
09-03-2008, 06:21 PM | #10 |
The crappy way to do it is to use your aux trim to steer the rear. That way is horrible as it takes a long time. Really your 3rd channel with that radio only has a 2 pos switch. If it had a 3pos switch you could atleast have full right center and full left, however this is not the case with your radio. I have the same radio that sits on the shelf and gathers dust. You can do it with trim but its more annoying then it is helpful. |
09-03-2008, 06:59 PM | #11 | |
09-03-2008, 07:00 PM | #12 | |
09-03-2008, 07:51 PM | #13 |
Newbie Join Date: Aug 2008 Location: latham
i use the traxxas tq3 which is am for my crawler and it works great i only get a glitch wheni put my outrunner in with my mm at high speeds. but i dont use the outrunner the low end isnt smooth enough for what im doing. with a brushed motor i get zero glitches. you can use the stock switch on the tq3 for rear steer its kinda tricky tho as you have to hold the switch in the middle for 2ws but its not that bad. i just havent gotten around to doing the 3 position switch mod to it yet so thats how i do my rear steer. the only thing with the tq3 is the recevier is pretty big so you gonna need room to mount it |
