09-04-2008, 12:33 PM | #21 |
I wanna be Dave Join Date: Sep 2006 Location: Stuck on a Rig in the middle of nowhere Utah.
Any tips on those "Custom Delrin, allthread, Revo links - thanks OffRoader5 " It looks like they sould hold up a long time.
09-04-2008, 01:36 PM | #22 | |
RCC Addict Join Date: Feb 2008 Location: Hiatus..sutiaH
09-04-2008, 03:27 PM | #23 |
Thank you, it realy helps to know what parts to get and where to get them. I am going to make some for my super. Could you also tell me how you angled the ends. Did you bend the all-thread?
09-04-2008, 04:59 PM | #24 |
I bent the all thread and it was hard, lol. But i have some crazy Steering throw!!!
09-04-2008, 06:38 PM | #25 |
Holdin my 40oz. Join Date: May 2008 Location: Somewhere in Colorado
Where are you guys in the pic with all the holes in the rocks
09-04-2008, 06:56 PM | #26 |
That came out real nice. Your parts list is alot like mine. I just need to get my hands on a dig and some REAL shafts that won't quit on me. There's not enough scratches on the lid yet.....I don't think you're being hard enough on it...you'd better send it to me |
09-05-2008, 04:32 AM | #27 |
I have a set up question for you. My Widow has a tendancy to lift a front wheel alot. It always drives out of it though pretty predictably. I am running Maxx shocks sprung with soft in front and pretty hard in the rear.... and very little weight in my front wheels. I have seen another BW handle like this too. I think I could either add more weight or soften the springs in the rear to get flex instead of lift... but I'm not sure I need to.
09-05-2008, 09:26 AM | #28 | ||
| We are at Palmer Park in Colorado Springs. Great place to drive. That was my first time though. Going back for sure. Quote:
Yup, get a dig. I cannot believe how effective they are. I will never run a rig without one now. Sharp turns, burns, hanging off ledges, etc... The VF is top notch. I luckily never stressed a shaft yet?! I did on carpet when I bound her up but that was it. I am still going to do the Maxx Shaft mod as I want 100% strength from her. Quote:
I am running a Traxxas Gray spring in the right rear with my Losi's. I have a 50 weight oil in that shock and 30 on the left. 20 up front on both. Like I mentioned, I do lift a little but I like it. When she is fully bound up though that Traxxas will give all the way. I love the setup!!! | ||
09-05-2008, 03:36 PM | #29 |
That's about what mine does. It's the strangest thing. It lifts up to the brink, then settles back down instead of rolling. I just wasn't sure if it was my setup or something common to the BW. |
09-05-2008, 04:33 PM | #30 | |
Quarry Creeper Join Date: Dec 2007 Location: At the Gates
for me, running a lipo is not Just about power. thats actually the last reason to run one. it is about having constant, even discharge throughout the whole run. also, they dont weigh much at all, which allows you to keep your weight in the tires (down low). you can get killer runtimes from low mah batteries. depending on my location, i can get over 3hrs of runtime off of a 2100 lipo. doc, wait untill you get some more "seat time" and you will go lipo too. | |
09-05-2008, 04:38 PM | #31 |
09-05-2008, 05:15 PM | #32 |
Newbie Join Date: Aug 2008 Location: Norway
Can you get your body fitted low on that chassis, doc? Bit hard to judge from your pictures how low you have mounted it. I feel like the body is fitted a bit high on the stock chassis. And as I am considering a new chassis, Id like one where I can have the body looow. Think it makes the crawler look meaner and leaner! So anyway, lol, hows yours fitted? As low as possible? Edit: I guess that also ground clearance plays a part here, doesnt it? Last edited by supah; 09-05-2008 at 05:26 PM. |
09-05-2008, 06:37 PM | #33 |
You can slam it really low with this chassis. Of course that is if you can keep your electronics and dig servo low. I'll try to get a pic up in a few, but with my test body, the tops of the tires are at or above the hood line.
