09-12-2008, 11:23 PM | #1 |
Pebble Pounder Join Date: Aug 2008 Location: San Jose
| Problem
Ok i got a new 55t novak, Now the trottle is extreamly glitchy, when i barely pull it to crawl, It jumps and glitches not a smooth speed. Any ideas why this is happening?
09-12-2008, 11:25 PM | #2 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
What ESC and Radio system are you using? What kind of battery?
09-12-2008, 11:26 PM | #3 |
Quarry Creeper Join Date: Dec 2007 Location: At the Gates
whats your speed conrtol/radio/battery combo?
09-12-2008, 11:26 PM | #4 |
09-12-2008, 11:29 PM | #5 |
The stanard esc that comes with the RTR and a 7.2 venom battery
09-13-2008, 12:19 AM | #6 |
Is the battery fully charged? Reset the adjustments on the radio, then turn it on, and then turn on the truck.
09-13-2008, 12:22 AM | #7 |
Ok i think i fixed it, But it makes a strange clicking sound some times now, The guy at the RC store said that it just needs to be warn in, is this true?
09-13-2008, 01:01 AM | #8 |
Quarry Creeper Join Date: Jul 2008 Location: Over a rock and under a bridge
Um, did he say the motor brushes need to be broken in or did he mean something else? The stock RTR ESC doesn't have very fine slow speed finese. We found a better alternative that worked out great for people like us on a budget. We switched the wires on the ESC and motor, then we changed the Throttle throw on the radio from REV to FWD. We got way better slow speed crawl out of the stock radio and ESC. The only issue was now you got the double pump forward, but at least reverse was instant! Give it a shot. |
09-13-2008, 01:39 AM | #9 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
I'm not sure what it is but the Novak motors are bad about having the "click"......especially in reverse.
09-13-2008, 08:32 AM | #10 | |
09-13-2008, 12:36 PM | #11 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
I'd say it has something to do with the way you have your antena routed and taped to the chassis.
09-13-2008, 12:43 PM | #12 |
09-13-2008, 12:56 PM | #13 |
Newbie Join Date: Jul 2008 Location: Delavan Wi
I have to agree with the other fella.The reverse circuit seems to have more steps than the forward. Ironic isn't it? I havn't tried it(replaced esc with mamba)but it makes absolute sense! Reverse comes on like a kitten with the stock esc. Forward:not so much!
09-13-2008, 10:36 PM | #14 |
| Ok, so how do i go about switching it? Im a little confused on how to do it. |
09-13-2008, 11:04 PM | #15 |
Newbie Join Date: Aug 2008 Location: somewhere
put capacitors on the motor, prolly interference. You'll wave that when the motor's frequency interfears with the trantmiter frequency, or maybe thats not the problem I'm just pissin in the wind tryin to help.
09-13-2008, 11:09 PM | #16 |
hmm im wondering how to switch it so my forward is extremely smooth like reverse is.
09-13-2008, 11:30 PM | #17 |
You got two wires coming out of your motor that is connected to your ESC. motor wires One black - this one is negative One red - this one is positive ESC wire going to motor Blue - negative Orange - positive They're both connected to the same color wire on the ESC. Reverse it. Connect the black wire from the motor to the orange wire from the ESC. Connect the red wire from the motor to the blue wire from the ESC. Now on your radio, you have a switch labeled Thr: REV NOR. I don't remember the default setting is at, but it's easy to figure out. Once you have the wires reversed, when you hit the throttle to go forward you're end up going reverse. So the fix is to change the switch labeled: Thr REV NOR to the other value. Now you're go forward when you pull the trigger again. Last edited by zoojunkie; 09-13-2008 at 11:50 PM. |
09-13-2008, 11:41 PM | #18 |
Rock Stacker Join Date: Aug 2008 Location: Lincoln
I think it also has to do with the cheaper radio that comes with the RTR. With the radio off try moving the "trigger" back and forth a couple of times every once and a while. This seemed to cure some of the problem I have had. I think the cheap pots on the throttle gets a little dirty and needs to be cleaned this way. Same thing happened on my Blade Cp heli until I switched over to my comp. radio. I thought of switching directions on the motor also, but it seems I do not have full throttle in reverse so I'm not sure I want to switch it. It's easy enough, I'll give it a try and go back if I don't like it.
09-13-2008, 11:46 PM | #19 |
Yah, you won't have as much wheel speed set up like this, but heck, it's free mod and gets you nice slow speed finese till you get a nice radio to use.
09-13-2008, 11:57 PM | #20 |
Newbie Join Date: Aug 2008 Location: lewisville
you dont want to go through all that wire switchin mess, just drop the center skid (with motor/tranny still attached) turn it around and put it back in.
