09-25-2008, 05:04 PM | #41 |
Quarry Creeper Join Date: Sep 2008 Location: sterling VA
09-26-2008, 02:25 AM | #42 | |
RCC Addict Join Date: Jan 2007 Location: San Jose
09-27-2008, 02:26 AM | #43 |
Quarry Creeper Join Date: Sep 2008 Location: Australia
Rear links now inboarded to the inside of the diff mounts and inside of the chassis with the shocks moved to the outside. Lipo mounted on front upper link. Damn this thing is soooo much better. Next up - shock oils and springs. |
09-28-2008, 09:13 PM | #44 | |
any other changes? | |
09-29-2008, 02:54 AM | #45 |
09-30-2008, 01:42 AM | #46 |
09-30-2008, 01:53 PM | #47 |
Newbie Join Date: Sep 2008 Location: hot
I battled this issue with weight and suspension adjustments. Running a good preload on my left rear, and running 9oz in each front plus a saddle pack, and getting the front preload settings dialed in seems to have done the trick.
10-01-2008, 02:27 AM | #48 | |
what did you do to get the front preload settings dialed in? | |
10-02-2008, 10:48 AM | #49 |
Using a couple lines that I consistently was having trouble with. I had someone give me a pretty good starting point, then I just tuned it from there. I am running the losi shocks, so adjusting them is a turn of a nut, on axials, you would use spacers... |
10-03-2008, 02:11 AM | #50 |
| okay. thanks. the point is just trying to reduce unload? or having a little compression before. ???
10-08-2008, 02:49 PM | #51 |
Quarry Creeper Join Date: Aug 2006 Location: CO burbs
I ended up with 80wt oil in the left rear with a 1/4" spacer added to the Ax shock, the front runs 60wt oil and is set up for about 1/2" droop using short springs on the stock Ax shocks. I tried Dynatrax shocks but didn't like them as much, but I have changed things out enough that they may work now. I run a 4 link in the rear and am trying to figure out how to do the front. I cut off the plastic mounting tubes on the axle to mount everything lower and now am stuck trying to figure it out......
