10-07-2008, 08:11 PM | #1 |
Quarry Creeper Join Date: Jul 2008 Location: looking for that perfect setup
| I Am Having Alot Of Troble Wich The Losi Shocks Please Help!!!!
I AM HAVING ALOT OF TROBLE WICH THE LOSI SHOCKS PLEASE HELP!!!! hi when i try to put on the top end on my stalk axial ax10 chassis it just wont work any one that can help please do!!!! |
10-07-2008, 08:17 PM | #2 |
Newbie Join Date: Jun 2008 Location: Rohester Hills
I'm not sure what you are trying to say, but let me take a guess. I think what you are having trouble with is the mounting of the top of the shocks on the chassis. First, use the rubber tubing that came with the shocks. Cut a piece that fits the space that the stock shocks took up. Then slide the rubber through the hole on the top of the shock and mount the shock with the chassis screws going through the center of the rubber piece.
10-07-2008, 08:21 PM | #3 |
yes that is what i am saying i will try it |
10-07-2008, 08:52 PM | #4 |
ok i got it on but when i push down it dosent spring up verey well is it cuzz i am useing 50wt
10-07-2008, 09:07 PM | #5 |
RCC Addict Join Date: Nov 2007 Location: BV
As long as the suspension isn't binding it shouldn't be a problem. I've used heavier weight oil with good success before. Also those springs are pretty light.
10-08-2008, 12:53 AM | #6 |
Newbie Join Date: May 2007 Location: omaha
You can also use the stock plastic mounts that come with the kit, you just have to cut them down to fit.
10-08-2008, 07:03 PM | #7 |
Rock Crawler Join Date: Jun 2008 Location: Clinton,Michigan
i use 55wt oil and i love it. you don't want your shocks to spring up allot. you want them smooth and a little giving. did you bleed the air out when you built them. if you want more springy get some stiffer springs
10-08-2008, 09:49 PM | #8 |
would the ajustable nut work?
