10-07-2008, 09:35 PM | #1 |
Rock Crawler Join Date: Jan 2007 Location: Northern Wyoming
| pede wheels fit axials?
looking for cheap wheels to glue some paddles on and don't want beadlocks. will front stammpede wheels fit the hexs on the axials or know of wheels that will. I have a set of wheels not sure what for and they don't fit.
10-07-2008, 10:08 PM | #2 |
Rock Stacker Join Date: Jul 2008 Location: alexander city
stock WK wheels or any wheel with 12mm hexs. I would look for dish type buggy wheels for sand or mud so they don't clog as much. Last edited by lucky13offroad; 10-07-2008 at 10:10 PM. Reason: info |
10-08-2008, 12:33 AM | #3 |
Newbie Join Date: Jun 2008 Location: kona
yes stampede wheels will fit or any other 12mm hub wheel
10-08-2008, 05:13 AM | #4 |
RCC Addict Join Date: Aug 2005 Location: New Oxford PA
| Not true. The extra material that sticks out on the Axial hex will not allow the stampede wheels to fit. Now you can drill a hole in the wheel or cut the extra material off the hex but an easier way would be to look for HPI wheels. they use the same style hex as the Axials
10-08-2008, 08:52 AM | #5 |
Newbie Join Date: Mar 2004 Location: LaCoste
TRUE you can istall stampede type wheels .all you have to do is remove the axial/hpi type hex and replace it with a flat surface 12mm hex.
10-08-2008, 08:55 AM | #6 | |
Rock Stacker Join Date: Aug 2005 Location: Findlay, Ohio
For non-beadlocks I use mainly HPI wheels. Tough and cheap! Here are some of the HPI wheels. Most of these come in 4 or 5 different colors, and the 5 star SS wheels com in 2 different offsets. http://www3.towerhobbies.com/cgi-bin...&I=LXPZD0&P=SM http://www3.towerhobbies.com/cgi-bin...&I=LXM875&P=SM http://www3.towerhobbies.com/cgi-bin...&I=LXM882&P=SM http://www3.towerhobbies.com/cgi-bin...&I=LXRD76&P=SM http://www3.towerhobbies.com/cgi-bin...&I=LXWX57&P=SM http://www3.towerhobbies.com/cgi-bin...&I=LXEWZ9&P=SM http://www3.towerhobbies.com/cgi-bin...&I=LXKSD2&P=SM http://www3.towerhobbies.com/cgi-bin...?&I=LXPZV1&P=7 | |
