10-08-2008, 10:09 AM | #1 |
Pebble Pounder Join Date: May 2008 Location: grand rapids
| help!! aftermarket servo batt plate
I am in the process of ordering a strc servo/batt mount and have no idea what length of tube to get for the servo?? I know the kit came with a 30mm link but I need to know what it will take once the servo is moved over and there are NO shops around here that carry this in stock. Any help will be greatly appreciated. J |
10-08-2008, 07:57 PM | #2 |
anyone??
10-08-2008, 08:01 PM | #3 |
I wanna be Dave Join Date: Aug 2008 Location: cape crud... will you be my friend
my servo is tubeless so im not sure. no i'm kidding, but is it the steering tube ? this is something that can be made if need be. |
10-08-2008, 08:05 PM | #4 |
Pebble Pounder Join Date: Mar 2007 Location: kalispell
i have the axial servo battery plate and it came with a smaller one that is 20mm, Hope that helps
10-08-2008, 08:30 PM | #5 |
Quarry Creeper Join Date: Jul 2008 Location: Erin, Ontario, CANADA
C'mon jreckner, where is your sense of adventure? Once you get the new plate and the servo mounted up, make up a new link by shortening the existing one (to the required length) with a Dremel tool. Then tap the cut end (3mm tap) and you're done! Narly1 |
10-08-2008, 10:27 PM | #6 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
fi you mount your servo to one side the tube to the long side will be 70 mm long i dont know it is to the short side:-( ck out my swx post and you will see |
10-09-2008, 08:31 AM | #7 |
lmao narly. thinking about it now, that is probably what I will do. I am adding a 20mm to my order just in case. thanks so much for all the info guys J |
