10-08-2008, 01:14 PM | #1 |
Newbie Join Date: Jan 2007 Location: Beaumont
| Kinda New
Mos Def new to the Axial scene but ive had a crawler b4... but it was a p.o.s Newbright lmao Im getting the AX10 Kit here in a bout a day or 2 so far i have Hammers with memory foam im still not sure how im going to jump into this ... if im going to buy everything needed at once or if im going to piece out the elecs and stuff. but i wanted your opinion.. my local hobbyshop has the bent links from STRC but 2 kinds both 30degree but one is bent in the middle and one is bent like you see it on the ARTR... i dont know what kind to get also if i should HD and Alum the F*** out of this thing right now or wait |
10-08-2008, 01:32 PM | #2 |
If you are planning on going for a comp rig, aluminum is the way to go! Not sure about the different links. Both will work good.
10-08-2008, 02:16 PM | #3 | |
Pebble Pounder Join Date: Oct 2007 Location: Belgium
Wait before buying too much. Build your rig, drive it for a while and see what needs improving. Thats the fun part of this hobby Also, either buy good stuff (servo, esc, search the site) or use stuff you already have like battery and radio. This way you dont waste your money buying everything twice. | |
10-08-2008, 02:19 PM | #4 |
ok thanks. im not sure about comp... i really wanna get rear steer but my good buddy 4x4boy says some comps dont alow that. i dont have a lot of time with work to do comps but when ever i go to my fathers in norcal i have a friend that i can crawl with and so it would mostly just be f'n around more than anything... but i like alum. cuz less breakage so ill prob end up doin it anyway |
10-08-2008, 02:22 PM | #5 | |
and Novak Rooster and 55t for 100 plus the kit for 250... but id still need servos and batteries and such. ill probably split it up like i had first planned | |
