10-08-2008, 04:59 PM | #1 |
Rock Crawler Join Date: Aug 2008 Location: Strugglin
| pinion
i bought a 10 tooth long pinion the problem is im not running a slipper so the pinion is to long. i havnt seen any short ones.really dont want to run a slipper how can i fix this and stay with low gears thanks
10-08-2008, 11:13 PM | #2 |
RCC Addict Join Date: Jul 2008 Location: San Diego
Did you try installing it the other way? The set screw to the rear. Or the set screw to the front? Im running a 10t with a 90 spur gear. Matt
10-08-2008, 11:23 PM | #3 |
Rock Crawler Join Date: Feb 2007 Location: wahiawa
another thing you can try is add a spacer in between the motor and motor plate...I use washers and run alittle longer screws for the motor screw
