03-30-2011, 12:24 PM | #41 | |
Pebble Pounder Join Date: Oct 2010 Location: In the dog house
Probably a good idea, but seeing as I am only running 2S and a 45 turn brushed motor, I imagine teh gears will last a good while. I only replaced the out gear because one of the out put hubs stripped. When somethign does fail, I usually go with a better replacement, but do not usually swap out things until they fail. Here is the bad part. | |
03-30-2011, 12:29 PM | #42 | |
I would be very surprised if the rotational mass difference is enough that you could notice it when driving. It would most likely take some precise equipment to measure the differences in acceleration. Especially when you consider that this gear is at the third point of gear reduction from the motor. Were it the spur gear it would have a much greater effect. Last edited by 02tac; 03-30-2011 at 12:52 PM. | |
