$100 upgrades wut upgrades would you guys suggest with $100 no digs or servos wut do you guys think about the ShaftD chassis? |
A shaft d or black widow an aluminum hubs and knuckles would be a good upgrade. Maybe some Losi crawler shocks if you don't need the aluminum. |
so the losi shocks are better than the axial ones??? |
These might help for upgrade ideas. http://stampedeproject.com/Axial-Tuning1 http://stampedeproject.com/Axial-Tuning2/ |
Wheels......After market beadlocks"thumbsup" |
I got a $50 Gift card to a online site that has a bunch of crawler stuff called eastendmachining.com I got thier dual reverse trianglation skid, 4 bent links, and the aluminum upper 3 link. i would also reccomend aluminum steering knucles and carriers too. |
wut shocks and springs would go well with the shaftD chassis |
I don't know what you have right now or not, but you should def looking into getting a split pack to put on the front axle if your still mounting the batt in the stock location, this will make the biggest difference, i would also recomend going to 4-link and rear bent links if you don't have them. |
where can i get the four link and how much are they??? i was planning on getting parts in this order 1. internal springs 2. stick on weights 3. losi claws and cut foams into stars 4. front and rear bent links 5. shaftD chassis 6. split pack 7. baja bug body |
you should def get the split pack first, that made such a huge! difference, i bought the 4-link here http://www.tcscrawlers.com/AX10-Scor...p-2-c-283.html it comes with everything you need, except for the rod ends, but i def recomend getting the split pack first. |
ShaftD $36 Axial Bent Lowers $12 TCS 4 link front and Rear $10 Panther tires $40 $98 Total Then save up for a Dig Set up. |
Go to a local tire store and ask for some of the stick on weights. Most places will give you quite a bit for free. |
MHO 1)Losi Claws/Panthers (terrain depending) and Memory foams (Weights are free at the tire shop, like Gixxer said, do that now) 2)Driveshaft upgrade (Stampede, MIP, Revo, Etc) 3)Split packs 4)New body of some sort 5)Hi-tech or JR Hi torque servo (Lets not start that debate either) 6)Long arm, parallel (as a starting point) 4 link for at least the rear 7)Losi Crawler Shocks or equivalent (as soon as you 4 link you'll destroy the stockers if you haven't already) 8)Aluminum beadlocks (Cuz by now you have surely stripped out the inside hex's of the stock wheels) I don't like internal springs. They limit the compression (Unless your a drooper) and are a pain to change. I prefer to limit extension of the shocks instead. I have made all these mods and more (Dig, front 4 link, moved tranny forward, etc) with out ever changing from the stock chassis. There are alot of people on this board that know 10x what I do, so I think most importantly you should spend some time browsing, because it will save you money in the long run. "thumbsup" Ask me how I know!:roll: Most of all Have Fun! |
i got some internal springs today, and velco to stick the electronics on but im gunna get the weights this week, and i havent got kit yet im ordering it on ebay this week |
also, wut company makes the baja bug body? |
and one more thing... i can keep the regular top links and get new rod ends for the four link right |
You should be able to use some of the spare rod ends in the kit to make the upper links. |
HPI did it has been discontinued (Might be able to find one on ebay). CKRC has a bug body which is really your only choice on the market right now HPI Bug Body: http://cgi.ebay.com/HPI-7154-Bug-Bod...1%7C240%3A1318 CKRC Bug Body: http://www.ckrccrawlers.com/shop/ind...oducts_id=1199 |
I have Two Parma VW Bug Bodies instock now.... |
