12-05-2008, 12:58 PM | #41 |
Rock Stacker Join Date: Apr 2008 Location: Windsor, VA
Thanks guys, I appreciate the info. Maybe i will just run it on my stock chassis for a while and get some use out of it before i buy somethin else. |
12-05-2008, 08:23 PM | #42 |
Pebble Pounder Join Date: Oct 2008 Location: So-Cal
sadly i sold my rig i will build another one soon, but on the other hand its for my new crf450
12-06-2008, 05:46 AM | #43 | |
12-06-2008, 07:39 AM | #44 |
Newbie Join Date: Apr 2008 Location: Frederick
I'm new to the rc crawler thing.Is the BWC a one to go with? |
12-06-2008, 08:07 AM | #45 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
12-08-2008, 09:59 PM | #46 |
Quarry Creeper Join Date: Aug 2007 Location: Morrison Crawlerado
Is anyone using Rustler shocks with their black widow? If so, what springs are you running?
12-09-2008, 08:29 AM | #47 | |
Pebble Pounder Join Date: Sep 2008 Location: lafayette
r2d and a puller will not fit | |
12-09-2008, 01:13 PM | #48 | |
Pebble Pounder Join Date: Oct 2008 Location: Indian Land/ Fort Mill
I am. In the front I am using the springs that came with the CKRC Level 2 kit, I cut them down to fit, very soft. In the rear, I hace some silver springs that I friend gave me. Not sure the type. They are medium soft. Personally, I hate the rustler shocks, too short for my taste, I need my clearance. | |
12-09-2008, 03:42 PM | #49 | |
12-09-2008, 06:16 PM | #50 |
Maxx shocks = good for me.
12-09-2008, 07:41 PM | #51 |
Rock Stacker Join Date: Aug 2008 Location: goochand
wat spring and weight oil are yall running with losi crawler shocks?
12-09-2008, 08:50 PM | #52 |
Pebble Pounder Join Date: Apr 2007 Location: Glendale, AZ
| MFM-Black Widow
Here are some pictures of mine. I bought mine before they offered the links. Specs: Hot-racing dig LOSI shocks Axial, etc., etc. I started by mounting the shocks in the typical position but found that under hard flex while turning the tires would rub the shocks. So I mounted the shocks to the far inside of the front axle and to the inside of the chassis. This allowed for excellent articulation (easy movement) up front and I could stiff'en the rear more to keep the torque twist down, since the shocks are at thier widest point. The truck runs good. This chassis is awesome in my opinion. I would recommend it to others. Last edited by kdubb88; 12-09-2008 at 09:13 PM. |
12-09-2008, 09:02 PM | #53 |
hmm i might have to try that
12-10-2008, 04:26 AM | #54 |
Kdubb- Can you get us a pic of how you have the front shocks mounts up top on the chassis? Thanks!
12-10-2008, 06:36 AM | #55 |
Quarry Creeper Join Date: Oct 2008 Location: Marysville
I ended up going to back to internal springs with mine, couldn't get the skid low enough after bolting up the rock grabbers. Right now I am at 2 3/4", hopefully that will keep the COG low enough, otherwise I'll have to go to a full droop. So far I really like the chassis though, can't even compare it to the stock chassis.
12-10-2008, 06:53 AM | #56 |
Hadn't seen this thread before, some good info in here Couple pics of mine, but wait where did the tranny and shafts go?? I love this chassis , think it works great on the moa ax-10 HR axles also |
12-10-2008, 09:11 AM | #57 |
Because of the motor and tranny you can't run the links on the inside?
12-10-2008, 09:20 AM | #58 |
I can, actually the rear links are in, this was just a test, i now run them inboard.
12-10-2008, 10:01 AM | #59 |
| I actually ran my r2d on my stock chassis and did not like it at all. Its geared way too low, noisy, and not smooth at all. So i went back to the stock axial tranny and i will put a dig on that.
12-10-2008, 10:04 AM | #60 |
